EGR Delete - Ford Powerstroke Diesel Forum
post #1 of 5 Old 05-20-2012, 05:01 PM Thread Starter
Mlivesay's Avatar
EGR Delete
Ok. So I'm new to the diesel community. I picked up a 2006 f250 about a month ago for a tow rig for my jeep. How can I tell if it has the EGR delete in it?
2006 F-250 CC Long Bed - Leveled, Updated Oil Cooler, Sinister EGR Delete, 4" straight pipe, Blue Spring, PHP Atlas 40 FICM Tune, Sinister Coolant filter, SCT SF3, Glow Shift Max Tow EOT ECT and EGT gauges, B & W Turnover, 6 DVD changer with headrest monitors, Sound Off Signal Emergency FD Lights, Cobra 29 LTD/BT
Mlivesay is offline
post #2 of 5 Old 05-20-2012, 05:41 PM
Powerstroke Techie
Lilpooh's Avatar
Feedback Score: 3 reviews
Can you tell if your studs are done from the outside
2004 F350 CC DRW King Ranch
X-3 tunes by DJ'S,QT,GH,ID. Gryphon FICM tunes, ARP studs,Stage 1turbo,ATS coolant recirc lines,Swamp's 48v ficm,coolant filter,AD2,Snow Perf stage II,EGR delete,4" turbo back straight pipe,S&Bintake,Quad "A" pillar autometer gauges,Suncoast Tri Disk Conv.,Billet input shaft,Suncoast superduty rebuild kit,Trans-go shift kit,Mag-Hytec trans pan,CFM+ elbow,ccv mod,15K reese 5er,17" LCD TV/DVD,Cobra 29 Nitewatch CB
Lilpooh is offline
post #3 of 5 Old 05-21-2012, 01:48 AM Thread Starter
Mlivesay's Avatar
Thanks
Mlivesay is offline
post #4 of 5 Old 05-21-2012, 02:13 AM
Term3's Avatar
Quoted: 2 Post(s)
Unless a "sneaky" delete was done where the inlet and outlet of the exhaust side of the EGR cooler are capped and welded closed.
SCT, no studs...yet, Dual OEM intake air filter housings, Banks intercooler & intake elbow, Banks exhaust system, Windrunner ported intake manifold, Bullet Proof Diesel remote oil cooler & thermostat, AirDog2 (plus a couple spares), Power steering filter (Amsoil dual-bypass), MagTec deep ATF pan, Electric oil pre-lub pump, Dakota Digital gauges.
Term3 is offline
post #5 of 5 Old 05-21-2012, 04:54 AM Thread Starter
Mlivesay's Avatar
Is there anyway to tell if that was done. OTHER than taking it off. I'm asking because I'm getting a little bit of white smoke in the mornings. And trying to knock out some ideas here.
Mlivesay is offline
