normal oil pressure range? - Ford Powerstroke Diesel Forum
Old 05-19-2012, 02:49 AM
Ive been searching and cant find a good answer anywhere. Ive did read that someone said they have seen as much as 150psi but the motor leaked alot of oil.
So I installed my new oil psi gauge and when I started my trk this morning when cold my oil psi was around 70psi at idle. After it was good and warm the idle psi was around 20psi. When I hit the gas pedle and boosted the turbo up some my oil got up to 90psi. I was under the assumption that my oil psi should be around 20 idle and around 60psi max.. What kinda psi should I see in a normal running engine?
Shark
Old 05-19-2012, 12:40 PM
anyone?
Should I not be worried if it hits 100psi?
