Weird whistle
So my question is about a whistle sound when I pull my fifth wheel. In august last year, took trip to the river. When I have truck in tow/haul mode, cooling fan cycles more often. And I also get this whistle sound that comes and goes. Louder than turbo whistles. Sounds like its cycling something, but not sure what the whistling is. Truck was completely stock at the time. Have turbo back exhaust and cold air intake now. Plus insight cts with egt. (and php ficm atlas 40 tune) (in about a week) so ill be able to monitor things. But I have no idea what that cycling whistle was. Any ideas? Always great info on this forum
Degas bottle cap maybe, but usually not that loud, a bit subdued. Turbo flex pipe maybe?
Sent from my SCH-I500 |
Flex line .... Like silicone intercooler boot? If its degas cap, .. means blown egr cooler or head gasket failure.. hope not that. Very loud in cab. Do the 6 o's have waste gates? And do they whistle?
The flex line he is referring to is the exhaust up-pipe and y-pipe expansion joints, looks like a shop vac hose. Over time thru heat cycles, the metal becomes brittle and cracks or breaks.
To check them, either look for soot around joints or firewall, and/or when the motor has cooled down start up truck and climb on the motor and feel for exhaust leaking. Here is a pick of the "flex joints"/expansion joints.
Where Is that in the engine compartment? Sorry, this is my first diesel. Just bought last june
If you want to get to know your 6.0 parts locations, check out this link. Start with the 2003 bible and work your way up thru the '04 and '05.
http://www.forddoctorsdts.com/articl...icle-06-08.php |
