Oil temp gauge
Where can I find a manual gauge to read oil and water temps.
All tips welcome. Thanks in advance. |
Scangauge II, trust me you wont be dissapointed.
You can use one of the temp gauges to watch two readings if you go with Autometer short swept temp gauges that have a single wire going to the sending unit. I have Autometer sport comp, short swept gauges that only have one wire going to the sending unit.
You will need a on/off/on switch, and another sending unit. The autometer short swept gauges take either a short sending unit probe (#2258) and/or a long sending unit probe (#2259). With the on/off/on switch, the center terminal will connect to the gauge. Then on the end terminals, one will go to a sending unit and the other terminal to the other sending unit. You will be able to flip the switch from one sending unit to the other. |
