CTS installed today...have a few questions - Ford Powerstroke Diesel Forum
post #1 of 14 Old 05-11-2012, 09:08 PM Thread Starter
Got the CTS installed today. In the drive home which was around 60-70 miles interstate/city/ mountain drive the EOT maintained 192 jumping up to 195 pulling a slight hill. ECT maintained 185 jumping to 190 pulling the same hill. Then came the 7% grade for about 4 miles i maintained 60 mph the EOT peaked at 202 and the ECT peaked at 200. Does everything seem to be ok or not? The biggest difference I saw between them was about 12* the EOT being the highest.
2006 F-350 SW CCLB Lariat 6.0 Auto
Diamond Eye 4" Straight Turbo back
Edge CTS insight
SCT X3 -- Looney --
Rowe06 is offline
post #2 of 14 Old 05-11-2012, 10:11 PM
rady2000's Avatar
Everything looks to be within specs to me!
2006 Ford F-250 Super Duty XLT 4X4
6" Pro Comp Lift
Diamo DI-8 20" Wheels
Falken WildPeak Tires A/T
Edge CTS w/ EGT Probe
XDP Coolant Filter
HID Headlights
SCT Performance Tune
4" MBRP Turbo Back Straight Pipe
rady2000 is offline
post #3 of 14 Old 05-12-2012, 04:03 AM
Quoted: 2 Post(s)
The difference numbers look good, but your coolant temp being 185 normal is low. From what I understand 190 - 192 is the normal range. Wait for more info here, but I think you may need a new thermostat.
2016 F350 Platinum
ralderman is offline
post #4 of 14 Old 05-12-2012, 04:30 AM Thread Starter
Ok ill keep a close check on it today on the drive home from work. This morning on warm up they both warmed up pretty close the same. So I'm hoping its gonna be fine untilled I can flush it and do the EGR delete
Edge CTS insight
SCT X3 -- Looney --
Rowe06 is offline
post #5 of 14 Old 05-12-2012, 07:33 AM
van-boy's Avatar
according to my cts, my ect runs between 196 to 210. eot is about 8 degrees higher.
bailey
cut me some slack, its a work truck.
van-boy is offline
post #6 of 14 Old 05-12-2012, 10:07 AM Thread Starter
ECT 192 Max Eot 202 Max and stayed anywhere from 5-12* difference. Does this seem to ok or do I need to do anything to it yet? Thanks
Edge CTS insight
SCT X3 -- Looney --
Rowe06 is offline
post #7 of 14 Old 05-12-2012, 10:15 AM
War is the answer!
WarChild's Avatar
Quoted: 24 Post(s)
That is well withing parameters. But.if.your ect is going below or has trouble reaching 190 your thermostat needs to be replaced. They are cheap and easy to replace.
White 04 F350 Lariat SRW/CC/LB/FX4 227,XXX+
Studs/BPD58V FICM Atlas40/BPD oil cooler/waterpump/7.3 fan
Edge insight CTS EGT/Turbo timer/FP SCT with ? Tune
Powermax w/KC billet wheel Warren 175/30%
5-8" MBRP Off Road Turbo Back/harpoon
2" Leveling/33' BFGATKO
ELC/PMM Coolant filter
aFe Stage2/EGR Delete
(Always Faithful) is the motto of the Corps. That Marines have lived up to this motto is proved by the fact that there has never been a mutiny among U.S. Marines.
WarChild is offline
post #8 of 14 Old 05-12-2012, 10:30 AM Thread Starter
Ok then I guess ill be changing the thermostat. Keeping a steady speed with very little load in the motor Ect will be 180-185 but soon as you start pulling harder it will reach 192. Thanks for the help
Edge CTS insight
SCT X3 -- Looney --
Rowe06 is offline
post #9 of 14 Old 05-12-2012, 10:41 AM
War is the answer!
WarChild's Avatar
Quoted: 24 Post(s)
Yea, definatly a bad thermostat. Ect should be 190-192 unloaded on flat surface.
WarChild is offline
post #10 of 14 Old 05-12-2012, 11:15 AM
rady2000's Avatar
That sucks, I have a brand new thermostat and my ECT's are about 182. Maybe cause its not a Motorcraft thermostat...
6" Pro Comp Lift
XDP Coolant Filter
HID Headlights
rady2000 is offline
