replacing head gaskets - Ford Powerstroke Diesel Forum
Old 05-11-2012, 02:13 PM
Question replacing head gaskets
does anyone know how hard it is to do arp studs and black onyx headgaskets yourself?
Old 05-11-2012, 02:15 PM
If you have a way to lift the cab it shouldn't be too hard. You also should get your heads checked for cracks, flatness and hardened seats
It's possible without lifting the cab but very tedious. Don't mind me asking why you running onyx head gaskets?
Old 05-11-2012, 02:26 PM
Dont use BO gaskets. Just got a call from my Brother in law today and his BO gaskets just failed on him.
Old 05-11-2012, 02:39 PM
Feedback Score: 5 reviews
If you do not want to do this ALL over again in a year or two you will want to use OEM Head Gaskets!
BO is getting a bad rep because too many guys are redoing theres
Please read this Poll I set up and peoples answers Before making your final decision... Also, If you already bought BO gaskets and feel bad for throwing them away... DON"T be.. would you rather spend an extra $300 on OEM now or have to REDO your heads and gaskets a year from now ($2-4k)
Let's Play a Game
Old 05-11-2012, 03:31 PM
Let's Play a Game
I agree... Its not worth the chance, Use OEM and have your heads check out before re-installing them.
Old 05-11-2012, 03:49 PM
BO gaskets Stink!
D
Old 05-11-2012, 06:24 PM
Let's Play a Game
no i dont have a lift unfortunitly I'm thinking it should say right on the 6.0 powerstrokes sticker DO NOT BUY UNLESS YOUR OWN A LIFT AND ARE A MECHANIC i'm glad i asked though before i went out and got a set of BO's
Old 05-11-2012, 06:38 PM
I've been using b/o head gaskets for a long while and we have good luck 35 ford construction trucks, factory is just as good, material wise.
Sent from my DROIDX using AutoGuide.Com Free App
Old 05-11-2012, 10:28 PM
This is the exact reason why I set up that thread that was posted above
Im sure B/O is "fine" but I DO NOT want to play that game with my 6oh... Stick with what works for sire and be safe rather then worry about it every day!
Sent from my crazy phone that posts behind my back...
Old 05-12-2012, 01:22 AM
I'm in the middle of doing this myself, but both heads were cracked. Get the heads magnafluxed. I have a extra set of oem gaskets due to buying the head kit and a bullet proof kit. But its not too bad its just hard on the back. If you have a basic set of tools you will be fine. Buy a high pressure oil rail tool though it will make it easyer. I may also have a set of oil stan pipes if you have a 05 or newer. I believe is what they are for. Pm me for help I will tell you what my problems were. Best of luck to you!!!
