P0148 - Ford Powerstroke Diesel Forum
post #1 of 2 Old 05-09-2012, 03:04 PM Thread Starter
P0148
I was making my weekly 200 mile trip home from work. And notice the fuel gauge was going down quicker than normal. I dont know what made me check my codes on the CTS but P0148 came up. Something about fuel delivery problem. What is this. Is this something I should e concerned about. Fuel Pressure is good about 62-65. Any suggestions I could use the help. Thanks
2004 F-250 Crew Cab 4x4
5" MBRP Turbo Back No Cat or Muffler
SCT X3 GearHead SRL
Edge Insight CTS
Glow shift 4 pod Gauges: Tranny, fuel pressure, EGTs, and Boost
Blue Spring Update
6.4 Banjo Bolts
Sinister Coolant Filter
AFE Stage II Cold Air Intake
More to come is
Studs, Oil Cooler, EGR delete, Coolant Filter, Air Dog, bigger injectors, and Water/Meth Injection
demott930 is offline
post #2 of 2 Old 05-09-2012, 08:12 PM
War is the answer!
WarChild's Avatar
Quoted: 24 Post(s)
Possible causes:
Fuel quality
Crankshaft position (CKP) or camshaft position (CMP) signal noise
Retrieve and record all engine and transmission DTCs.
Is DTC P0148 present?
Yes:
CARRY OUT a drive cycle. REFER to Section 2 .
REFLASH the PCM. If DTC P0148 is present again, INSTALL a new PCM.
I would start by checking the voltage on the FICM. Ether it or the PCM is going bad or you have crap fuel would be my guess. If your FICM test good wait till you fill up again to replace the PCM.
White 04 F350 Lariat SRW/CC/LB/FX4 227,XXX+
Studs/BPD58V FICM Atlas40/BPD oil cooler/waterpump/7.3 fan
Edge insight CTS EGT/Turbo timer/FP SCT with ? Tune
Powermax w/KC billet wheel Warren 175/30%
5-8" MBRP Off Road Turbo Back/harpoon
2" Leveling/33' BFGATKO
ELC/PMM Coolant filter
aFe Stage2/EGR Delete
(Always Faithful) is the motto of the Corps. That Marines have lived up to this motto is proved by the fact that there has never been a mutiny among U.S. Marines.
WarChild is offline
