Going to replace the OEM head bolts - Ford Powerstroke Diesel Forum
Old 05-09-2012, 08:27 AM
Question Going to replace the OEM head bolts
Finally found someone in my area that I feel confident with. Going to get the head bolts, egr delete and new oil cooler. Anything else I should have done while they are in there? Also I need some opinions on the best tow tune on the market. Will be towing a 15K 5th wheel through the foothills of the carolinas...
Thanks!
Old 05-09-2012, 09:02 AM
Have them replace the HPOP screen, Upgrade Turbo drain tube, Upgrade Hpop fitting and be sure to have the heads properly machined... Ie:
Machining:
- Resurface the heads
- Install new valve stem seals
- Install new rocker box gaskets
- Exhaust Manifold Gaskets
- Magnaflux and pressure testing
- Inspect for cracked seats, worn valve guides
As for tow tune, I run innovative diesel's tow and love it!
