could use some advice in buying 6.0l - Ford Powerstroke Diesel Forum
post #1 of 7 Old 05-09-2012, 08:13 AM Thread Starter
hey im new here but im thinking about buying a 05 f250 with the 6.0l it has 83k on it. took it for a test drive the other day everything seemed great about it looked brand new for its year. i have the vin# the carfox is clean, but i didnt know if anyone on here could help me out with the oasis report
wizlams08 is offline
post #2 of 7 Old 05-09-2012, 08:20 AM
Special's Avatar
Quoted: 2 Post(s)
You should take it to a different dealer to get checked out. Most will charge $100 to do a through inspection. They will let you know of any potential problems. A Carfax report is worthless. I almost bought a vehicle with a spotless Carfax, car was 2 years old. I took it to a dealer to get checked out. They printed out the service record and it had been in the shop over 30 times for electrical problems. They put it on the lift and they even showed me where it had been in a serious accident that required frame repair. None of those were on the Carfax. That $100 saved me 20 thousand.
2005 Stampede Edition F-250 SuperDuty 6.SLO Diesel
4" Lift on 37" Toyo MTs ( IT CAN BE DONE ! )
Barder Stage 2 Turbo-Warren 175/30 Injectors-WPE Stage 3 Intake-DD RR-CTS2 Monitor-ARP Studs-BPD Remote Oil Cooler-Amsoil Custom 2 micron Full Flow Oil Filters-Sinister(Coolant Filter & CAC Pipes)-CCV Mod-Special's Fenderwell Mod-4:30 Gears-Grizzly Locker-Custom 5" Dual Straight Pipe Exhaust-AFE Momentum Intake-SCT Custom Tuned-Kleinn(630 Train Horns & Onboard Air)-HIDs-JL Audio-and Zoodad.
Special is offline
post #3 of 7 Old 05-09-2012, 08:26 AM Thread Starter
alright i'll see if i can take it to another garage thanks for the tip
post #4 of 7 Old 05-09-2012, 08:36 AM
Special's Avatar
Quoted: 2 Post(s)
Just be sure to take it to a Ford Dealer. They will have access to all of the REAL Service records.
Special is offline
post #5 of 7 Old 05-09-2012, 08:38 AM Thread Starter
the only problem is the closest ford dealer is a half hour away
post #6 of 7 Old 05-09-2012, 12:12 PM
Buy a scangauge 2. It will tell you if your
Deltas are ok between your coolant temp and oil temp. They should be less than 15* at 65 on flat. I run 6* to 10* on flat with 11000lbs gvw. I learned the hard way. Spend the 160 bucks and save yourself 1000nds in the long run. You will need the sg2 with any 6.0 but it can be used in any modern vehicle. Read the sticky too. Good luck.
04 f350 cc,sb 4x4, scangauge, egr delete, new turbo, 08 oil cooler, Schaffer's 5w40 synth oil, 4" exhaust, s&b intake, arp studs sct matts 280,xxx miles cooper st/maxx
94 f250 cummins 12 v 4x4, Lincoln SA250 Perkins cooper st/maxx
03.5 f350 sc, lb, drw 4x4 Rebuilt motor at 201000 egr delete, new oil cooler, 54v ficm, new rad, water pump, 4" exhaust, arp studs ,sct, new injectors, sinister coolant filter, srl, tow tunes and erics tow, cooper tires, Flatbed, vantage 300, 202xxx miles
neffco is offline
post #7 of 7 Old 05-09-2012, 08:47 PM Thread Starter
well the truck sold today. but now since i have time im thinking about trying to a 6.4l psd. but the only thing is that i really like the body style of the 05, 06,07 models but the 08's with the 6.4's their starting to grow on me and opinions
