engine chugs at 50 mph--egr? - Ford Powerstroke Diesel Forum
Old 05-08-2012, 04:39 AM
Check light on--diagnostic says EGR valve or EGR short circuit. Replaced EGR about 2,000 miles ago. Still chugs. Warranty'd so I will replace again. What next?
Old 05-08-2012, 12:27 PM
Pull the egr valve is it moist?
Old 05-08-2012, 06:52 PM
Mine was doing similar, only as EGT's exceeded a certain point while lugging the engine (usually in OD at 50-55 mph, I got no codes or CEL though). I was advised to try unplugging the EGR valve once it is closed (engine off), and see if that resolves the issue. In my case, it did, so I need a new EGR valve.
I should probably mention, before I had my head studs/gaskets done, the head gaskets were leaking, and the engine exhibited very similar symptoms.
Old 05-09-2012, 03:08 AM
No white smoke, so I dont think its a head gasket issue. Belches black smoke on acceleration and hills. EGR is not moist, but covered in soot when removed and cleaned last week. Is EGR delete needed or is it an injector issue?
Old 05-09-2012, 03:51 AM
You need a new EGR valve. Deleting it is a separate decision.
Old 05-09-2012, 05:45 AM
What head gasket brand did you use? Please don't tell me you used Black Onyx?
Old 05-09-2012, 06:05 AM
sounds just like mine, so I'd agree it's likely the EGR valve malfunctioning. Might be a good idea to check the wiring, just in case, especially since you had replaced the valve recently.
nope, used Ford gaskets. 60k since Christmas, no problems.
Old 05-09-2012, 07:07 AM
talked to Alliantpower--on the EGR--take it off, make sure that valve setting is closed and replace--but do not connect electrical and see if it runs better. If so, its likely the EGR or wiring. If not, it make be something is sticky in the turbo. Will try the EGR deal and see if it helps.
Old 05-09-2012, 03:02 PM
Keep in mind this info. EGR valve removal and fan clutch issues
