Idler pulleys, bearings? - Ford Powerstroke Diesel Forum
 3Likes
post #1 of 17 Old 05-07-2012, 02:01 PM Thread Starter
Powerstroke Techie
Lilpooh's Avatar
Quoted: 11 Post(s)
Feedback Score: 3 reviews
Do all the idler pulleys share the same bearing number (6203)? I replaced one of the pulleys years ago, and seen that the one I replaced was your standard 6203 sealed bearing that was just pressed in.
Got a squeaky one, and have access to free bearings!!!!
2004 F350 CC DRW King Ranch
X-3 tunes by DJ'S,QT,GH,ID. Gryphon FICM tunes, ARP studs,Stage 1turbo,ATS coolant recirc lines,Swamp's 48v ficm,coolant filter,AD2,Snow Perf stage II,EGR delete,4" turbo back straight pipe,S&Bintake,Quad "A" pillar autometer gauges,Suncoast Tri Disk Conv.,Billet input shaft,Suncoast superduty rebuild kit,Trans-go shift kit,Mag-Hytec trans pan,CFM+ elbow,ccv mod,15K reese 5er,17" LCD TV/DVD,Cobra 29 Nitewatch CB
Lilpooh is offline
post #2 of 17 Old 05-07-2012, 02:26 PM
War is the answer!
WarChild's Avatar
Quoted: 24 Post(s)
You mean "we" right?
Stiles likes this.
White 04 F350 Lariat SRW/CC/LB/FX4 227,XXX+
Studs/BPD58V FICM Atlas40/BPD oil cooler/waterpump/7.3 fan
Edge insight CTS EGT/Turbo timer/FP SCT with ? Tune
Powermax w/KC billet wheel Warren 175/30%
5-8" MBRP Off Road Turbo Back/harpoon
2" Leveling/33' BFGATKO
ELC/PMM Coolant filter
aFe Stage2/EGR Delete
(Always Faithful) is the motto of the Corps. That Marines have lived up to this motto is proved by the fact that there has never been a mutiny among U.S. Marines.
WarChild is offline
post #3 of 17 Old 05-07-2012, 02:27 PM Thread Starter
Powerstroke Techie
Lilpooh's Avatar
Quoted: 11 Post(s)
Huh??? "we"?
Lilpooh is offline
post #4 of 17 Old 05-07-2012, 07:22 PM
Quoted: 27 Post(s)
I believe they do use the same bearings
Mark
06 F250CC SB FX4 Lariat;ARP studs;OEM gaskets; Banks exhaust;DynaTrac Ball joints;Coolant filter; High-Idle;RACCCV6000;JimmiJammers;Ravelco;SynchroMax trans case;Fumoto valves;Harpooned;CPOhighwayProducts toolbox;tracrac;Fox Weatherboots;Wet Okole Seat Covers;BriteBox;Re-flashed;Quadzilla Recon XZT Fuel Press;Blue FPR spring;DashDAQ;PHP FICM;RiffRaff boots;DCPower270AXP;PowerInverter;Rancho7000's; BPD EGR cooler;One-piece HPOP fitting;BilletWaterPump;SCT w/ Matts SRL;ELC Ultra
bismic is online now
post #5 of 17 Old 05-07-2012, 08:08 PM Thread Starter
Powerstroke Techie
Lilpooh's Avatar
Quoted: 11 Post(s)
Thanks Mark, I'll confirm this tomorrow while I have it apart.
Lilpooh is offline
post #6 of 17 Old 05-07-2012, 09:29 PM
Quoted: 27 Post(s)
Lilpooh -
I found this:
Tensioner bearings (both) and smooth idler pulley bearings: 6203-2RS
Grooved Idler bearings: 6303-2RS
McMaster-Carr
Stiles likes this.
Mark
post #7 of 17 Old 05-08-2012, 01:58 AM
Motor Head.
robertc68's Avatar
Quoted: 40 Post(s)
Lilpooh -
I found this:
McMaster-Carr
Yep those are the exact numbers,I ordered.I did mine while the engine was out.
04 350 DRW CC LB,4:10,245/75/17,tires 4X4..Coolant filter. CTS.Stage II AFE.EGR Delete,Zoodad ,regulated return, ,Arp,OemHG,AD150,WPE ported int,58FICM,190/30 Injec,05 coil conversion.WPE/KC 1.5 turbo,2011 rear leafs,13 tailgate,flight fab trac bars.2014 Power/folding/Extend mirrors.
robertc68 is offline
post #8 of 17 Old 05-08-2012, 04:11 AM
War is the answer!
WarChild's Avatar
Quoted: 24 Post(s)
It was a joke pooh. You said you have access to free bearings.
WarChild is offline
post #9 of 17 Old 05-08-2012, 04:30 AM Thread Starter
Powerstroke Techie
Lilpooh's Avatar
Quoted: 11 Post(s)
Thanks Mark & Robert!!
Warchild, Ha Ha!! I get it now! LOL!!
Lilpooh is offline
post #10 of 17 Old 05-09-2012, 04:09 PM Thread Starter
Powerstroke Techie
Lilpooh's Avatar
Quoted: 11 Post(s)
Lilpooh -
I found this:
McMaster-Carr
For those of us that have dual alternator set ups, the above post is correct for the primary (main) belt/pulleys. The pulleys for the dual alternator set up all use the 6203-2Rs.
Lilpooh is offline
