Towed the camp trailer, a few questions..? - Ford Powerstroke Diesel Forum
Old 05-06-2012, 07:10 PM
This weekend we went fishing and hauled the camp trailer. It is a bumper pull that weighs approx 5,000lbs fully loaded. I had used the tow tune by Vivian with the Jake Brake. The truck seemed to haul good and I think everything went well. It was about 250 miles and 3.5 hours each way on a lot of mostly flat land, but there was a few large hills.
Here are the questions I have:
A couple of times this trip on the long or steep hills the ECT would hit 230 degrees and the EOT would hit 240-242 degrees. It was also 95 degrees outside. Is that too high, is there something I should be worried about?
Also I noticed that the truck would "turbo fart" almost all the time when I would let off the pedal. It doesnt do it that much when the truck isnt towing or when it is tuned with the looney tune instead. Is the "turbo farting" a result of the towing, the tow tune, ???
I was also towing the 5,000 lb trailer at about 65-70 mph, tried to keep it under 2000 rpms except for on the hills, and over all I was trying to be easy on it. I only got 9 mpg, I was hoping to get better than that with the tow tune and a light trailer. Does that mpg seem low for what I am towing?
Thanks,
Will
Old 05-06-2012, 07:26 PM
War is the answer!
Im not sure about those temps they seem a bit high to me but everything else seems normal. You can get the air shock spring helper thing and you will get a bit better mpg. What state are you in?
Old 05-06-2012, 08:58 PM
Will
The temps are a little high with ECT at 230* and EOT at 240-240* but it still under the 15* spread did you hear the fan come on mine come on around ECT 212-214* sounds like a jet plane. The highest that i have seen pulling my 14k 5er temps running ECT 218* EOT 228* pulling a 7% grade about 6 miles long in 90* weather and i get 9mpg and solo i get 18.4 by hand, not the lie-o-meter.
2 stroker
Old 05-07-2012, 07:28 AM
Mine made a fart sound towing 5k under engine braking in tow haul when thhe exhaust backpressure in the EGR cooler would pressurize the cooling system, blew out the egr cooler on that trip.
