The Superduty left side lean????? - Ford Powerstroke Diesel Forum
Old 05-04-2012, 05:04 PM
I have personally known and now own a Superduty with the left hand lean.
I am exactly a half inch low left front and left rear. It really doesn't matter on fuel level and I am not the biggest dude out there.
I have an ebay 2 inch leveling kit on the front. Stock rear suspension with airbags out back.
My current plan without moving springs all over the place is to buy a 2.5" leveling kit and use the 2.5 inch block on the left front and leave the 2" on the right front.
Out back I will try to find a half inch shim to add to the spring pack via the leap spring center pin. If that is too much of a pain in the *** I will likely run 10 extra pounds in the left rear air bag.
Anyone else dealt with this? what did you do.
I hear ford spec for leaning trucks is 3/4".
Old 05-04-2012, 06:00 PM
They all all lean
Old 05-05-2012, 07:12 AM
Its not leaning! Your truck just has swag!
Old 05-05-2012, 02:34 PM
well i was noticing that as well but the thing that i am coming up with and you have to look at the frame twist vid of the powerstroke and the duramax and listen to people on here is the frame is like a semis and its suppose to twist so i think that the lean is so when its under power or load it sits level, i have noticed that with the tune and ficm tune just getting on it a little will pick up the front and drop it a good bit
Old 05-05-2012, 03:11 PM
Both my ford trucks got a decent lean
Old 05-06-2012, 07:07 AM
War is the answer!
Mine has swagg too.
Old 05-07-2012, 07:33 AM
This compensates for road crown, many other brands have it too. Some gm trucks dog track as well for the same reason.
Old 05-07-2012, 08:18 AM
No, there is nothing designed into the truck to create the lean. The springs and everything left-right are identical. It is due to the fuel tank and driver being on the left side. I plan to swap my rear springs side-to-side to see if that helps, I have about 1" lean right now.
Old 05-07-2012, 10:20 AM
My dad's 04' had the same problem. Ended up being a broke leaf spring.
Old 05-19-2012, 11:12 AM
18 bucks and 30 minutes of work and she's all fixed up.
Within an 1/8th inch left to right.
If anyone needs a 2 inch or 2.5 inch aluminum spacer for their front leveling kit let me know as I now have one of each laying around.
No broken springs here, thankfully.
