First time towing the goose! - Ford Powerstroke Diesel Forum
Old 05-03-2012, 05:03 AM
I went and bought a goose neck about 400miles away yesterday! its a 24k capacity but just had a smaller 14k bumber pull trailer loaded on top. My ECT was a steady 218 and EOT was 238 running 70 on mild hills from GA to FL. On the longer steeper hills ECT went up to 228 for a short bit. But no puking or coolant lose. the truck is a completely stock 2003 F350 with a flat bed. Those temps seem high to me what do yall think?
Thanks,
Tim
Old 05-03-2012, 05:45 AM
Came into thread expecting pics of said trailer..
left dissapointed....
Old 05-03-2012, 06:15 AM
PICS to satisfy the masses
Old 05-03-2012, 06:24 AM
the ECT/EOT delta "test" should be done unloaded at 65mph cruise, on mostly "level" HWY, start test when ect has reached a min temp of 190degrees F, check ECT/EOT deltas 5 to 10min later, if temp delta exceeds 15degrees F, likley cause is clogged oil cooler.
Thanks,
Tim
Old 05-03-2012, 12:50 PM
USMC 0311
I dont think he was really asking about the ECT EOT delta test I think he was just asking if those temps were good given his speed, load, and terrain.
Sorry I cant comment on that issue as I dont do much towing.
Old 05-03-2012, 01:09 PM
I just towed 22k through the rockies and my highest coolant temp was 232 going up the pass to the eisenhower tunnel.
Old 05-03-2012, 01:27 PM
well dang that doesnt make me feel all warm and fuzzy.....
Old 05-06-2012, 09:14 AM
BS............
Old 05-06-2012, 10:50 AM
that is the test to check for clogged oil cooler, Explain BS ?
Originally Posted by HeavyAssault View Post
BS............
Old 05-06-2012, 11:49 AM
You are talking it as if you stepped into it.............
http://www.phila.gov/fleet/Warranty%...sb09-08-03.pdf
