fuel psi gauge
Im getting ready to order some gauges.. Do I have to have that stickly diesel adapter to hook the sending unit up to the fuel test port or can i just by a 1/8 adapter thing? Will the sending unit hit the radiator hose?
use the search. i think it does but sombody on here put in a 90 elbow for 2.49 or something like that
bailey |
The adapter is REQUIRED because the test port is metric and most gauges are NPT. Depending on which gauge you use, the hose is not an issue.
Yes an adapter with a 90* fitting will allow you to come right off the test port. No need for that hose.
Ok
Thanks, Ill look for that 90 adapter. I just had a hard time spending $50+ on a hose if I didnt have to have it. |
Nope, that's the test port on the fuel regulator. I bought the gauge and sender as a package on E-bay, Cybertronics I think, works well enough.
With the 90 degree adaptor there is plenty of room to clear the CAC tube. |
I have the same exact fitting DELTAJOHN has i just went to FASTNEL and got the fitting for like 1.00
tried looking this item up on fleabay but no luck. was this setup pretty easy to install and what gauge did you end up using? do you have a write up on this install?
