coolant flush ? - Ford Powerstroke Diesel Forum
post #1 of 1 Old 04-26-2012, 05:13 PM Thread Starter
coolant flush ?
Is restore the only thing that will clean out the radiator. I called some semi truck dealers and they are using some stuff called ERF. Has anyone tried this or anything else for that matter. Also how do you know you are at 185 or 190 degrees. Last but not least do or don't you take out the t-stat. It would drain faster but wouldn't it take longer to heat up and get the restore to work?
sbb888 is offline
