Band Clamps
Just ordered a 5" straight pipe and want to use band clamps where I can.. Do I order the pre formed or flat band clamps?? Im still new to this whole thing!!!
I'm not sure where you are going with "pre-formed" but I think you mean U-bolts or simply muffler clamps. Anyway, If you can get them to stay tight the flat clamps are pretty cool. After fighting with muffler clamps, I welded my stuff. The only use for muffler clamps now is to hold the exhaust to the hangers.
depending if your going with id or od. I think thats the term, but if the pipe is the same size and will not slide into each other i think you need a regular one. If one end is bigger i believe you will need the pre-fit like you are talking about. Sorry im not sure on the correct names for piping
I use SS band clamps when I re and re the cat for emissions testing. They work slick and seal really well. Takes about 15 minutes each way. Got them from International for about $10 a piece.
The preformed clamps are for use with a slip fit where one pipe slips into the other. The flat clamp is for a butt fit where they just meet end to end.
