Help make final parts selection
Hey yall,
So I finally had the sad face thing happen, big gross plumes of white/ blue erupt from my tail pipe at startup and take off. Anywho I knew it was coming so I found a local shop to do the work and flash my FICM. I have a list of parts I have or plan on getting in the next couple of days. What I need from you is anything that "NEEDS" to get done while I am balls deep in my engine bay. Synthetic Oil/ New oil Filters New fuel Filters Full EGR delete (FCDP) Intake Manifold Gaskets ARP Headstuds OEM Head Gaskets Oil Cooler Rebuild Radiator Flush Turbo refurbish (planning on attempting this one myself) Zoodad Mod Adding iTSX Tuner with Custom Tunes from Matt (gear head diesel) Additional things to know about the truck: 2004 Supercab Long bed FX4 2003 "red sticker" 6.0 PSD 123xxx miles I appreciate your feed back and please feel free to hit me up I am stuck on a 24 Hr Staff Duty (stuck at a desk waiting for the Phone to ring) so I will be trolling the forums all day and night. thanks guys |
What kind rebuild on the turbo if I'm not wrong u have to make sure its balanced or u could be in a world of mess. Also If u doing a egr delete and all that id throw on a coolant filter kit since there inexpensive also when I did the work on mine as well as u are I did the upgraded banjo bolts as well
Ehhh... I found a ford reconditioning guide for the turbo and all it mentioned was o rings... as far as the banjo bolts I suppose I never really understood what they did for the fuel rail or what the difference between doing just the front ports vs all 4 would be.
and a chill filled the room... how about this has anyone run 5w30-40 synthetic? is there any noticible advantages other than engine longevity. Brands people swear by etc etc.
Most guys on here are runnign eitehr Shell Rotella T6, AMsoil, or Mobile 1 TDT bottom line, as loong as your running a good syntehitc and good quality, lubricated fuel you'll keep your injectors happy and running for a long time Goodluck |
The stock banjo bolts have more restriction than the upgraded and lot of ppl using 6.4 banjo ur not going to notice a diff at all. Ithink my upgraded ones was like 15 bucks Maby few more dollars I can't remember
I suppose adding a Blue spring kit might benefit me as well as far as the banjo bolts I have been reading alot of conflicting reviews as to the validity of them not to mention reading how the fuel system works I think the banjo upgrades would be a detriment... but I may understand this wrong.
But i look forward to any other suggestions. Im pretty sure I have everything that needs to get done, but if there is anything else you can think of please let me know. |
Ok please for the love of god someone please explain what I need to do the head gaskets... I see some sets that come with what I presume to be head gaskets ranging from 150-300 (single oem vs both gaskets) and then there are sets that range from 400-660 that have all kinds of freakin seals and rubber grommets Ive never seen before... lol trying to find reasonable OEM head gaskets and ARP studs thats it... they dont even need to be in a combo lol Please help me
Ok well... I got everything else. Now my FICM is on the fritz.... I am going to have that rebuilt. I was also informed I should replace the HPOP Oil discharge Tubes and High pressure oil coupler. Is there anything else that anyone can think of (big or small) that I need to replace while I'm balls deep in my engine bay.
I appreciate your input Last edited by Vudue Priest; 05-01-2012 at 04:22 PM. |
I feel like a forum leper... Any chance anyone can link me to HPOP oil discharge tubes? It seems google has nothing for me...
