why are these wires cut? - Ford Powerstroke Diesel Forum
Old 04-25-2012, 08:39 AM
why are these wires cut? sorry no pics but when u open the hood right hand side toward the front there are some wires cut when i bought the truck why?
someone told me something too do with trailer ???
Old 04-25-2012, 08:47 AM
Feedback Score: 5 reviews
Those are the "cab pass through" wires...
they are made so if you need to run any wires through the firewall you wont need to... they are alread ran from the factory
the other end is under your feet behind/ next to the fuse panel
Old 04-25-2012, 09:06 AM
L&B L&B is offline
Gee, I'm really glad that this thread popped up before I finished running the wires for my pyrometer. Thank you!
Old 04-25-2012, 09:16 AM
if it's a standard probe the pyro wire can come into the cab at a better spot down by the accell pedal and u don't need to run the ground all the way into the cab as you probably know
plus the pass through wires are a biotch to access at the inside termination IMHO
Old 04-25-2012, 09:26 AM
L&B L&B is offline
[hijack] Type K thermocouple, Autometer 3544. No ground on probe. [/hijack]
Old 04-25-2012, 09:47 AM
cool
some like mine have 2 wires
there is an penetrable aluminum style foil covered plate near the drivers side exhaust where most people install the pyro u can see it from under the truck ,, thats so easy to use
Hi Jack over .. sorry OP
Old 04-25-2012, 09:51 AM
wait so what are them wires for then im lost... just like to hook up stuff like pyro meter?
Old 04-25-2012, 09:52 AM
they are for anything u want as long as the wire size matches up to the proposed load
Old 04-25-2012, 09:56 AM
I hooked up my extra set of fog lights and ran the power line using one of those wires to my switch inside my cab!
Sent from my crazy phone that posts behind my back...
Old 04-25-2012, 10:01 AM
this has the locations of the blunt cut wires at both ends ,, disregard the up fitter installation
Installing Upfitter Switches - Ford 2005-2007 Superduty
