TFT? how high is too high? - Ford Powerstroke Diesel Forum
post #1 of 7 Old 04-24-2012, 04:34 AM Thread Starter
Hey guys, im just curious as what would be too high for trans fluid temp driving around town. my truck ( 2005 F350 SCLB 4x4 ) usually runs between 150 and 160 degrees. i have gearheads srl and i noticed as i was playing around through town a bit my TFT went as high as 170. does this seem ok or a little high? i have a trans cooler from another truck in my garage in perfect shape. it has 3/8 inlet/outlets, would this be ok to install or would the supply and return have to be bigger? the trans shifts good and fluid is clean but i want to check on this before it becomes an issue. thanks.
jasonlx is offline
post #2 of 7 Old 04-24-2012, 04:41 AM
ADMIN AND TECH
SCUFFY828's Avatar
150-160 is just fine , in my opinion 170 isnt too high
ITS STOCK
SCUFFY828 is offline
post #3 of 7 Old 04-24-2012, 07:20 AM
2 High= 200-220*
At 170* just right.
2 stroker
06 F350 4x4 PSD Lariat FX4 CC LB
Edge Insight CTS Expandable Pyro
AutoMeter Fuel Pressure Gauge
Updated Fuel Reg. Kit 3C3Z-9T517-AG
Amsoil By-Pass(Amsoil 5w40)
Delo ELC Coolant
Coolant Filtration System
pulling a 14,000 lb Alpenlite 5er
97 F350 4x4 PSD CC LB
PacBrake&ATS converter lockup
3" dp 4" exhaust
TruCool 28,000 lb cooler
Tymar Intake
A piller EGT,Boost,Trans
2 stroker is offline
post #4 of 7 Old 04-24-2012, 07:22 AM
amdriven2liv's Avatar
Quoted: 4 Post(s)
Too high would be 230.
The tranny has a t-stat in it. Opens at 165*. The highest I have seen was during 95* outside temps, pulling my 8000# travel trailer up a 6% grade, 180*
Here is a good tranny thread:
TorqShift Transmission - Information and Troubleshooting - Ford Truck Enthusiasts Forums
2004 F350 6.0L CC LB 4x4 King Ranch
amdriven2liv is offline
post #5 of 7 Old 04-24-2012, 07:26 AM
Slacker
Evil Eye's Avatar
Quoted: 207 Post(s)
Feedback Score: 4 reviews
Also, just want to mention that my analog tranny temp sender seems to be "off" compared to what I'm reading with my Edge Insight CS unit. The analog gauge is showing about 30*F warmer than what is showing on my CS...
Shawn Carlson
Proud Navy Vet
2005 F250, CCSB, 6.0 PSD, FX4 (The Sweet Unit is white)
2008 F350, CCLB, 6.4 PSD (Brad-the wife's truck is black)
Engine Mods:
Fluidampr
CCV Reroute (Reinstated)
4" MBRP Exhaust
MTW Stage 1 Turbo
Bulletproof 53V FICM
BulletProof EGR Cooler
BulletProof Water Pump
Riff Raff Intercooler Boots
Gogo Diesel Direct Drive Solenoid
BulletProof All-Aluminum Radiator
BulletProof All-Aluminum Intercooler
BulletProof Oil Cooler System w/ Bypass Filter
SCT w/ Custom Tunes (TSD, DJ's, Innovative, Gearhead, QuickTricks)
Exterior Mods:
Bilstein 5100 Shocks
Icon Adjustable Trac Bar
Firestone RideRite Air Bags
BDS Dual Steering Stabilizer
Aluminum Finned Differential Cover
Reese 16k Manual Slider 5th Wheel Hitch
Icon 2.5" Leveling Kit w/ F-350 rear blocks
20" BMF Novakanes wrapped in 33" Nitto Terra Grapplers
Evil Eye is offline
post #6 of 7 Old 04-24-2012, 07:37 AM
Galaxie's Avatar
I have seen 170 towing 10K with AC on in 100* temps when driving though the Appellations.
I was hauling like 80/85mph. Thinking about that first ice cold beer when I got to MD had the skinny pedal down low.
Colin
59-68Galaxies, Fairlanes
54 Ford Skyliner Glass Top
60 Country Sedan Wagon
87/93 5.0s 347
Buy/Sell/Trade/Service 40s50s60s cars!
06 F350 Dark Stone XLT FX4
SCTX3 Custom Tunes
ARP Head Studs
EGR Cooler gone
MBRP Stright Pipe
Edge Insight
20" Harleys 35" AT2
2011 Tailgate
Eaton TrueTrac
2" Leveling
Black Windows/lights
Blue Spring
03 Turbo
Galaxie is offline
post #7 of 7 Old 04-24-2012, 05:37 PM Thread Starter
hey thanks for all the replys, there`s 175,000 miles on my tranny and just wanted to make sure things looked healthy. it seems to work spot on but it never hurts to ask. thanks again.
jasonlx is offline
