Tow/Haul Shift Lever - Need Part# - Ford Powerstroke Diesel Forum
post #1 of 1 Old 04-23-2012, 07:18 PM Thread Starter
I need the part # for the entire automatic shift lever with the built in tow/haul button. They sell them on e-bay, but they are the "overdrive" model not the "tow/haul" model. If someone knows the number or has a link that would be great.
I have a 2005 F-250.
Here's what I have come up with:
My broken wire issue must be inside the lever itself. I have pulled the entire lever off and checked the entire length of the exposed wire and there is absolutely no cut in it. I have also checked all the fuses. The only possible thing that is left is that the actual wires connecting to the "tow/haul" button have gone bad somehow. The problem is that you can't get to the connection inside the lever.
Jon
indyjon is offline
