gasket/up pipe
Does anybody make a gasket that goes between the exhaust manifold and up pipe for the drivers side,mine has a slight leak ? Thankss
I don't believe there is a gasket for that connection....I had mine all apart this weekend and didn't have one come out. Are you tightening each nut a turn at a time until they're tight?
Yes you are correct,there is no gasket.I thought some were adding a gasket.I tightened them evenly and torque to 20 ft lbs, my manifolds are coated and that could be it,they look to be mating good but there is a slight leak.
Does it squeal or can you feel the air?
Does the coating on your manifold interfere with the mating surface?
Yes the coating does interfere.
I see it's ceramic coated...taking that stuff is not easy. It has to be heated and aluminum oxide blasted off. You may have to call a coating company and see if they can get it off for you.
try a thin layer of Permatex ultra copper rtv, stuff works damm good
