HPOP differences? - Ford Powerstroke Diesel Forum
post #1 of 6 Old 04-20-2012, 05:36 AM Thread Starter
HPOP differences?
For 04 6.0 there are 2 different HPOP's offered and I am trying to figure out what the difference is can anyone help?
lurch405 is offline
post #2 of 6 Old 04-20-2012, 05:43 AM
You need to know the date of when your engine was manufactured (or check where your ICP sensor is located). Ford changed the design of the oil rail and how the HPOP connects up.
Ford also changed the HPOP to a V4 piston style beginning in the June 2004 production run - IIRC though, these were for only the 2005 model years.
If your ICP is behind the turbo, then you need 3C3Z-9A543-AARM
If your ICP is on the passenger valve cover, then you need 4C3Z-9A543-AARM
Mark
06 F250CC SB FX4 Lariat;ARP studs;OEM gaskets; Banks exhaust;DynaTrac Ball joints;Coolant filter; High-Idle;RACCCV6000;JimmiJammers;Ravelco;SynchroMax trans case;Fumoto valves;Harpooned;CPOhighwayProducts toolbox;tracrac;Fox Weatherboots;Wet Okole Seat Covers;BriteBox;Re-flashed;Quadzilla Recon XZT Fuel Press;Blue FPR spring;DashDAQ;PHP FICM;RiffRaff boots;DCPower270AXP;PowerInverter;Rancho7000's; BPD EGR cooler;One-piece HPOP fitting;BilletWaterPump;SCT w/ Matts SRL;ELC Ultra
bismic is offline
post #3 of 6 Old 04-20-2012, 06:02 AM Thread Starter
Thank you that is exactly what I needed to know.
lurch405 is offline
post #4 of 6 Old 04-20-2012, 06:06 AM
Term3's Avatar
As far as I know there was only one, the swash plate type in 2004. In 2005 there was two, the swash plate type and the piston type. The older type was used in some models like the Excursion.
SCT, no studs...yet, Dual OEM intake air filter housings, Banks intercooler & intake elbow, Banks exhaust system, Windrunner ported intake manifold, Bullet Proof Diesel remote oil cooler & thermostat, AirDog2 (plus a couple spares), Power steering filter (Amsoil dual-bypass), MagTec deep ATF pan, Electric oil pre-lub pump, Dakota Digital gauges.
Term3 is offline
post #5 of 6 Old 04-20-2012, 06:28 AM
There are two valid part numbers for 2004 HPOPs - for the reasons noted earlier.
But you are correct that there are only two pump designs
Mark
bismic is offline
post #6 of 6 Old 04-20-2012, 07:19 AM
Term3's Avatar
Yah I really hate how Ford used the Excursion as their method of getting rid of all their left over parts.
Term3 is offline
