Edge insight installed EOT/ECT delta results.
SO I finally got the insight installed and threw the extreme tune on from innovative. On the way to work this morning I checked the EOT/ECT, after reaching operating temp I was cruising at 60MPH and it was never over a 6 degree difference. After driving for a while going up slight grades and hitting about 70-75 mph it did get higher but never went over 10 degrees. WHats everyones thoughts on these results? Am I nearing a cooler replacement? I planned on doing the EGR delete and oil cooler upgrade very soon but wanted to see where I stood temp wise first.
Thanks for any input. |
Your deltas are fine 6* most of the time and 10* max nothing wrong with that, your oil cooler is OK
2 stroker
Your temps are fine.
I haven't done the flush yet but will be doing it soon. If it changes Ill just do the oil cooler as planned. If not I'll just do the EGR delete.
Would you expect the delta to increase or decrease after doing a flush?
Some people increase cause it breaks crud lose then plugs oil filter
