bullet proof oil cooler temps? - Ford Powerstroke Diesel Forum
Old 04-18-2012, 04:05 AM
I installed the bullet proof diesel oil cooler and egr cooler this past weekend. my oil temps and coolant temps are both lower by about 10 degrees according to my scangaugeII. i have two questions. 1) the oil tmeps being reported by the scangauge are actually the oil leaving the transfer block to go to the cooler? 2) has anyone ever measured the oil temp coming back into the engine ( after oil cooler temp)?
one other question: has anyone noticed better cooling of both radiator and oil cooler with the install of a aftermarket front grille?
Old 04-18-2012, 04:21 AM
What are your ECTs? Hopefully not too low.
Old 04-18-2012, 04:34 AM
ECT 190 to 195
EOT 190 to 200, although the oil temps take a LONG time to get to 190
Old 04-18-2012, 04:57 AM
Unapologetically American
Feedback Score: 4 reviews
I don't know about the temps, to and from the oil cooler, but I do know that the radiator is VERY efficient now without the oil cooler load. The oil WAS warmed by the coolant, therefore did so, faster. Now, them being two separate systems, they will act a bit different. I'm still running the stock grill (winter use), but I'm looking at a new one (summer use), but it has much less restriction
I'm only wanted a summer grill because my OE one is trashed from rock chips, not for any more cooling affect
Old 04-18-2012, 05:55 AM
Slacker
Yes, Dee004 measured it and his temps at the oil block were 170*F and his temps after the cooler were around 140*F. Oh and Nick explained the reason that your coolant temps are a bit slower to come up to temp.
Old 04-18-2012, 05:59 AM
Feedback Score: 3 reviews
Are you sure that the BPD oil cooler has the EOT sensor reading at the oil out to the cooler??
That would not make sense, because oil temps would be higher than normal. The PCM monitors EOT to command the fan clutch and engine defueling if the EOT get to a certain temp.
I would imagine that BPD put the EOT sensor on the manifold for the return line coming from the cooler. Your best bet would be to contact BPD to get a final answer if the EOT sensor is before or after the cooler.
Old 04-18-2012, 06:07 AM
Slacker
Here's Don's post with his observations. If it was reading the temperature on the return line, the oil temp increased by 30*F just going through a 6' length of hydraulic hose.
Originally Posted by dee004 View Post
There are a couple of points to make here.
First, I didn't report the temperatures post cooler this time because I found they may have been confusing the issue. The post cooler temps were still 146 to 148 the whole trip on my pillar gauge reading that sensor. It reports the temperature of the oil leaving the cooler feeding the bypass filter not the actual engine oil temperature in the block. The engine oil temperatures from the engine oil temperature sensor in the Bulletproof billet block were 172 degrees. Also clarified by Evil Eye a few posts back
Old 05-15-2012, 05:45 PM
I just did the oil cooler and egr cooler myself. I haven't been able to take it for a long drive to test it out yet. The ect was around 198 constant and eot kept raising to almost 240. Now with driving about 10-15 miles both on streets and freeway the ect is fluxes between 190-192 and the eot took forever to get to 186 and as soon as I slowed down or stoped it dropped very quickly
Old 05-15-2012, 07:31 PM
Well sounds like your thermo is stuck open.
I transposed the C and O in the ECT and EOT
Old 05-15-2012, 07:59 PM
War is the answer!
Which part of that says thermo stuck open? If the thermo was stuck open the temps would be in the 180's and would never reach 190.
