injector problem, sputtering - Ford Powerstroke Diesel Forum
Old 04-17-2012, 04:54 PM
My truck has this wierd issue ever since I've bought it
happens cold or at operating temperature
If I hammer on the throttle and go WOT sometimes the truck will downshift like it should but it will go up to about 2500 rpm then hit a brick wall wont accelerate at all and sputter horrible, it pours out blueish gray smoke when this happens so I let off the throttle and it stops then get back into it gradually and everythings fine
its really starting to piss me off.
I'm thinking its a injector, I've cleaned the egr valve twice since I've bought it
this is copied from fte i couldnt find a response
can anyone on here give me a hand
Old 04-17-2012, 05:08 PM
Sounds to me like a boost leak. When you back out of it and roll on slower boost levels climb slower thus requiring less fuel. When you hammer it vgt duty cycle goes through the roof thus needing more fuel but without air you get bluish grey smoke! Id start by looking for a boost leak, probably one of the cac couplers.
Old 04-17-2012, 07:14 PM
Depending on mileage I would go with an injector(s). I just did injectors but my truck has 240k ok it so it was about time. Could also be stiction as I had that problem also. Rev x can help but won't entirely fix it. But I see in your sig that you have 96k so I wouldn't think it could be injectors. Maybe get em buzz tested and see what comes up.
Old 04-17-2012, 07:39 PM
Im going to pull all my cac boots and check them, especially the hot side ones
Truck now has 104k miles, all injectors original
Running mobil 1 5w-40 full syn turbo diesel oil with a dose of archoil 9100 I also have no stiction issues
I hooked up AE to my truck but it was after a 15 mile drive so everything was warm during diagnostics, I had some low boost code, but nothing else all injectors passed buzz test and contribution test, ficm is working 100%
Im not sure about fuel pressure but I do know I do not have the blue spring upgrade
Turbo was reconditioned 10k miles ago and up pipes are new also
I do not remember the low boost code but I know that's what popped up
Now that I wrote all this, im starting to lean away from injectors as being the problem
