HPOP 03 vs 04 1/2 - Ford Powerstroke Diesel Forum
Old 04-15-2012, 09:53 PM
HPOP 03 vs 04 1/2
I have an 03, can I change over to the later 04 1/2 High Pressure oil pump?
Old 04-16-2012, 04:55 AM
Turbos = Witchcraft
You can but it is a pain. You would have to retrofit your engine with the High Pressure oil Lines from a later truck, get a new HPOP cover, and a new engine wiring harness to relocate your ICP sensor.
Why would you want to do that anyway. if your 03 HPOP is going out and you want a better one, just buy an adrenaline pump (which they only make in the 03 style currently) and that will last longer and outflow even a later pump.
Old 04-16-2012, 07:31 AM
^^^What he said.
