Originally Posted by nordstrom
Just switched to running Rotella Synthetic was wondering what the safe limits for my EOT for short and longer periods of time are. I never let it get over 230 when running standard oil, is that still a good temp to not exceed. Have the BPD EGR cooler and soon will install the BPD Oil Cooler conv kit (hopefully by the end of summer)
2006 F350 Lariat CC SWR 4x4
Edge Evolution
S&B Air Intake
BPD EGR Cooler
Everything Else Stock
Thanks in advance
It's not the dino or Syn oil it's the difference between ECT-EOT that counts. Just so you know i run a 5w40 Syn oil and my ECT 192-194* EOT 198-200* solo then when i pull my 14k 5er add 10* to each. The highest i have seen is ECT 218* EOT 228* pulling a 7% grade 6 miles long in 90* weather. Looks like you need to do a coolant flush a must before you do the new oil cooler or you may be doing another one later or if you do a $2400 BPD oil cooler you should be good then but you also need to install a coolant filter to remove the casting sand.
2 stroker
