Manifold to up pipe bolts. - Ford Powerstroke Diesel Forum
Old 04-15-2012, 04:26 PM
Any tips to loosening the drivers side up pipe to manifold bolts? I swapped the turbo out, and the y pipe to turbo inlet seal looked perfect, but when I started it I didn't get any whistle, and there is a little smoke coming from around the y pipe. So clearly there's an exhaust leak. I'm having trouble holding the bolt so it doesn't turn when loosening the nut. Any tips/recommended tools?
Old 04-15-2012, 04:45 PM
they are a pain, I had more luck getting a wrench on the top and ratchet on the bottom, both from underneath. Painful... start with hitting it with some of the rust remover, bolt loosener stuff.
Old 04-15-2012, 05:16 PM
get a friend! use the wrenchs that are a half moon they will be easier than a straight one
Old 04-15-2012, 05:27 PM
HMM HMM is online now
I used a wrench that had a pivot head on it for the top side and was able to get a long extension with a swivel end on my impact wrench from the bottom. It sucked but did the trick.
I also soaked them the night before in knocker-loose.
Old 04-15-2012, 06:09 PM
JUst cut them off with a dremel and put some new ones in. Mine were not moving at all, but you might save time since you;ll want to replace them anyways,
Old 04-15-2012, 06:51 PM
Glow Plugs Only
Heres what I did to get at mine. Got tired of p,,,,,g around trying to get angle wrenches etc on the heads of the bolts. Bent a 1/4" extension and used it to hold the bolt and another couple of extensions and air wrench to loosen and tighten the nuts all from underneath the truck. Worked slick
Old 04-15-2012, 07:01 PM
Just got it done! And she's whistling!
I had my dad laying over the engine and holding the bolt with a combination wrench while I loosened the nut with a ratchet. It sure was a pain, but we got it done. Thanks guys.
