Ford Gold coolant goo/oil cooler question? - Ford Powerstroke Diesel Forum
post #1 of 8 Old 04-14-2012, 04:34 PM Thread Starter
Quoted: 6 Post(s)
The goop that gets caught in the oil cooler (not the casting sand or rust and scale), is it circulating around the coolant system as "goo" already or does it turn to goo as the coolant passes through the oil cooler when it comes into contact with the heat from the cooler? I am just trying to figure out at what point and how it actually turns to goo. Thanks
DENALI is offline
post #2 of 8 Old 04-14-2012, 04:46 PM
roche837's Avatar
Quoted: 5 Post(s)
Garage
Feedback Score: 4 reviews
The silicate in Ford Gold eventually breaks down or falls out of suspension with excess heat. Coolant passing throught the egr cooler is subject to alot of heat and eventually over time breaks the coolant down, This is when you will see your deltas becoming an issue.
EMPIRE STATE STROKERS
Studded, 5" exhaust, Sinister EGR DELETE / Coolant Filtration, more to come
roche837 is offline
post #3 of 8 Old 04-14-2012, 05:56 PM
Baddestt's Avatar
Quoted: 8 Post(s)
Flush the gold with fresh coolant and distiller water every 50k miles. I use the gold, but have a bullet egr cooler, stock oil cooler...not a single issue in 80kmiles
'07 F-250 PSD 4x4
5" exhaust, zoodad, blue spring, Airaid intake, 6.4 starter, 2.5 f/coils, adj Trac bar, 2" r/add-a-leafs, egr delete, snow plow fan clutch, csf 6028 intercoolerr, DC 185 alt, Bilstein 5100, Barder '03 turbo rebuild w/RR billet wheel, SCT SF3 tuner, F-Detroit Truetrac, R-Detroit Locker, 4:10 gears, hawk LTS, LT315/70r17 Duratracs, Amsoil Gear lube, Delo 400 LE 5w30 diesel, Delo ELC, archoil, bpd ficm, BPD oil cooler, dynatrac pro steer ball joints, arp studs, oem gaskets, HD water pump, stc, plugs, stand pipes, 6.4 banjo bolts,
Baddestt is offline
post #4 of 8 Old 04-14-2012, 09:04 PM
RIP Mitch ! We miss you
PGreenSVT's Avatar
Feedback Score: 3 reviews
This answer the question?
RIP Mitch
the Org crew
PGreenSVT is offline
post #5 of 8 Old 04-15-2012, 10:55 AM
L&B
Here's my theory - Whats the BEST Stuff to use - and I'm sticking with it until there is contradictory evidence.
L&B is offline
post #6 of 8 Old 04-15-2012, 11:57 AM
Quoted: 8 Post(s)
Good post L&B - can't believe I had missed it.
This is the closest explanation that fits all of the evidence IMO.
It explains why MANY people who still run tunes and have fully functioning EGR systems do not have issues w/ the Gold. Nitrite depletion and heat in excess of a good running system seem to be required to get the gelling.
Mark
06 F250CC SB FX4 Lariat;ARP studs;OEM gaskets; Banks exhaust;DynaTrac Ball joints;Coolant filter; High-Idle;RACCCV6000;JimmiJammers;Ravelco;SynchroMax trans case;Fumoto valves;Harpooned;CPOhighwayProducts toolbox;tracrac;Fox Weatherboots;Wet Okole Seat Covers;BriteBox;Re-flashed;Quadzilla Recon XZT Fuel Press;Blue FPR spring;DashDAQ;PHP FICM;RiffRaff boots;DCPower270AXP;PowerInverter;Rancho7000's; BPD EGR cooler;One-piece HPOP fitting;BilletWaterPump;SCT w/ Matts SRL;ELC Ultra
bismic is offline
post #7 of 8 Old 04-15-2012, 12:27 PM
L&B
Thanks Mark! It really pleases me that you seem to get what I was trying to say.
L&B is offline
post #8 of 8 Old 04-15-2012, 12:54 PM
Quoted: 8 Post(s)
Thanks for posting!! I was aware that glycol based systems can break down to the acetals - just hadn't researched the mechanism or connected it w/ nitrite depletion. I was assuming it was heat based (and Ford hints at it as well - they also hint about mixing w/ combustion gasses as an issue). As said before though - that didn't explain why some folks w/ HEAVY tunes (still running the Gold and the EGR system) don't have issues. Most of the folks I know that run that way are VERY meticulous about flushing the Gold coolant at reduced intervals (keeping the nitrite levels where they should be and thus stabilize the system). I think those same folks watch their deltas (ECT vs EOT) also. Oil coolers can frequently plug from casting sand, grit, and rust particles also. The resulting reduced flow can then initiate the reaction (at more elevated temps than normal) that you talk about in a functioning EGR system. I think that my thoughts fit yours - please don't hestitate to correct or add-on if they don't.
Mark
bismic is offline
