Blue Smoke? - Ford Powerstroke Diesel Forum
Old 04-14-2012, 07:22 AM
Blue Smoke?
well as the title says, i am having blue smoke out the exhaust. the weird thing is that it only happens when taking off from a stop ( stoplight, stop sign). I have heard from people that it could be a turbo seal.
Old 04-14-2012, 08:34 AM
bump
Old 04-14-2012, 10:35 AM
back to business
Turbo seal is a good bet. Does it go away / get better when everything is at operating temp? How much smoke? Does it ever smoke while idleing?
Easiest way to tell if it's a turbo seal is to disconnect the down pipe from the turbo and see if there is any gooey/burnt oil residue inside the pipe.
Old 04-14-2012, 04:46 PM
It is the worst when i first start driving then it gets better. It completly dissapears after 1st gear.
Old 04-14-2012, 04:53 PM
Yup, sounds like a turbo seal.
Do you have a CCM on it?
Is the turbo drain tube the Updated one?
Old 04-14-2012, 04:55 PM
back to business
I had very similar symptoms when my turbo seal was leaking.
Occasional smoke at idle when cold, quite a good puff when leaving from a stop when cold, disapeared after I was moving and when the truck was up to temp.
Check your down pipe.
Old 04-16-2012, 04:50 PM
Ok now that ive diagnosed the turbo seal, how do i fix it?
