Stiction cold start issue. Help?? - Ford Powerstroke Diesel Forum
Old 04-13-2012, 02:27 PM
Whats all your thoughts on injector stiction I have all 8 ford reman injectors. About 3-4 montages ago started to get white/blue smoke out of tail pipe I use 15-40 retella ever 5000 oil changes and ford filters. Was thinking next oil change use syn 5-40. What all your thoughts about this??
Old 04-13-2012, 02:34 PM
I use Rotella T-6 5-40 synthetic and REV-X and it seems to have cleared up my stiction issues. You need to also check your FICM to make sure you do not have a problem there.
Old 04-13-2012, 03:45 PM
It's at 48.5 cold and hot and ect eot only get about 2-5 degrees apart when hot. Problem is only cold starts.
Old 04-14-2012, 05:43 AM
over at the garage they are using archoil products with great results
ARCHOIL PRODUCTS SPOKANE - HOME
How it works
http://www.archoil.com/index.cfm/products/
No i am not a salesman,just relaying information which is, i believe,useful to the forum members
Old 04-14-2012, 11:16 AM
Why is it that folks wait till they are experiencing stiction before deciding maybe it's a good idea to run synthetic motor oil? The information on stiction is all over the Net.
Old 04-18-2012, 04:59 AM
I also have the latest ford reflash. Could that have anything to do with it. Is anyone having any problems with the reflash? Also could the thermostat have anything to do with the way injectors fire? It takes a while for it to warm up just a thought...
Old 04-18-2012, 07:59 AM
In my case I did not really get into finding out what the problem was until the truck went out of warranty. I just let the dealership fix it until I was going to have to replace injectors out of pocket, then I got serious about finding a permanent solution.
Old 04-19-2012, 05:09 AM
5w-40 syn and Rev-x fixed mine way back when. I have also heard amazing things about Archoil. I will probably start running it as a preventative maintenance thing with my new injectors.
Old 04-19-2012, 05:35 AM
Had one injector go bad over 2 years ago. Been running hot shots secret ever since, no issues since, what so ever. Use valvoline premium blue 15 40 every time. Also they sell the hss at tractor supply now, so easier to get it now.
Sent from my DROID X2 using AutoGuide.Com Free App
