Amsoil oil filter ok to use? - Ford Powerstroke Diesel Forum
post #1 of 30 Old 04-13-2012, 12:29 PM Thread Starter
I hear much regarding the use of aftermarket filters and just stick with FOrd/motorcraft. I got the filter with the purchase of my amsoil, you think its safe to use?
2006 F250
K&N intake
6" Pro comp lift
37x13.50x22's
SCT Custom tunes
Edge Insight W/Pyro
shaved door handles
Blue spring upgrade
EGR welded/deleted
Sinister coolant filter
Guntruck is offline
post #2 of 30 Old 04-15-2012, 07:23 AM
jhowell's Avatar
That's all I use for a oil filter. I use the EA15K88, it is a 15,000 mile filter. Or you can use the SDF88, its a 5,000 mile filter. Not sure as to the one you have. I do extended drain is why I use the EA15K88. Hope this helps?
Sent from my DROID2 using AutoGuide.Com Free App
08 F-350 CC Long bed
4x4 6.4 Lariat
H&S Black Max
Flo-Pro Exhaust from down pipe back
S&B CAI
Nitto Terra Grapple AT 275/65/20
jhowell is offline
post #3 of 30 Old 04-15-2012, 10:51 AM
RIP Mitch ! We miss you
PGreenSVT's Avatar
Feedback Score: 3 reviews
I really hope you are having your analysed. I have proven to Amsoil that their oil shears from a 40 weight to a 30 weight within 7k miles. I love Amsoil and run it myself but it is not safe to run extended oil change intervals. I have never seen a UOA report for a 6.0 with oil in for 10k or more that recommended you run it longer. Yes I get my oil tested and I change it at 7k to 7500 mile intervals. Amsoil 5w40.
RIP Mitch
the Org crew
PGreenSVT is offline
post #4 of 30 Old 04-15-2012, 10:57 AM
jesilvas's Avatar
Quoted: 2 Post(s)
You mean a bypass filter or the OEM filter placement?
4R100, 2wd
330,000 + miles
jesilvas is offline
post #5 of 30 Old 04-15-2012, 05:49 PM
jhowell's Avatar
Yep, I pull a sample every 5,000 miles. Next change I will be installing a bypass. -
4x4 6.4 Lariat
H&S Black Max
S&B CAI
jhowell is offline
post #6 of 30 Old 04-15-2012, 06:11 PM Thread Starter
Regular oil filter, I have it but if theres a realistic risk of using it over the motorcraft or ford filters I will just use the ford. THe amsoil filter has a smaller micron filtration so I have it and was tempted.
2006 F250
K&N intake
6" Pro comp lift
37x13.50x22's
SCT Custom tunes
Edge Insight W/Pyro
shaved door handles
Blue spring upgrade
EGR welded/deleted
Guntruck is offline
post #7 of 30 Old 04-15-2012, 06:14 PM
The aftermarket filters had issues that were created by trying to get around patents. Who knows if the Amsoil filters are in the same boat, but it is a small price to pay just to stick w/ OEM (IMHO anyway).
Curious - What is the amsoil filter's particle filtration rating and flow rating?
Mark
06 F250CC SB FX4 Lariat;ARP studs;OEM gaskets; Banks exhaust;DynaTrac Ball joints;Coolant filter; High-Idle;RACCCV6000;JimmiJammers;Ravelco;SynchroMax trans case;Fumoto valves;Harpooned;CPOhighwayProducts toolbox;tracrac;Fox Weatherboots;Wet Okole Seat Covers;BriteBox;Re-flashed;Quadzilla Recon XZT Fuel Press;Blue FPR spring;DashDAQ;PHP FICM;RiffRaff boots;DCPower270AXP;PowerInverter;Rancho7000's; BPD EGR cooler;One-piece HPOP fitting;BilletWaterPump;SCT w/ Matts SRL;ELC Ultra
bismic is offline
post #8 of 30 Old 04-15-2012, 07:46 PM
When I punch in my '04 Excursion 6.0, Amsoil recommends 15w40. Just wondered why you use 5w40....do I need to change? I live in North Carolina in case climate needs to be factored into it.
2004 Excursion Limited 4x4
Current additions
Edge Insight CTS
EGT probe
4" exhaust w/5" tip
Wish list
Coolant filter, blue spring, banjo bolts, ARP head studs
SCT from Vivian @ Quick Tricks
Tow Mirrors
Leveling kit
33" Nitto's
Kenwood multimedia w/navigation
'05 headlights and grill
Clearance lights
jcamp309 is offline
post #9 of 30 Old 04-15-2012, 08:27 PM
jesilvas's Avatar
Quoted: 2 Post(s)
Amsoil recommends whatever the Ford book says.
I'm sure they recommend all kinds of other stuff, but why just use the base level. Why not go better and get the better oil?
Filters are a different story though on a 6.0. Better turns out to be OEM.
4R100, 2wd
330,000 + miles
jesilvas is offline
post #10 of 30 Old 04-15-2012, 08:34 PM
Is this in response to my question on whether to use 15w40 or 5w40? I use Amsoil, just wasn't sure whether I should change the weight of the oil. Are you saying 5w40 is the better oil?
Current additions
Edge Insight CTS
EGT probe
4" exhaust w/5" tip
Wish list
Tow Mirrors
Leveling kit
33" Nitto's
Clearance lights
jcamp309 is offline
