PLZ HELP!!! Need Heads! - Ford Powerstroke Diesel Forum
post #1 of 20 Old 04-10-2012, 07:25 PM Thread Starter
King Rancher_27's Avatar
Post PLZ HELP!!! Need Heads!
Well it seems that I have a problem with my already studded 6.0. I got my truck studded and deleted at @ 91,000 mi and now have 101,and change. Acouple weeks ago I noticed coolent burping out of my cap so i went and picked up a new one from ford and didnt fix my prob. Hooked a guage up to my degas bottle and got 18 psi before I knew it. My guess is hg or cracked heads. Since we just did all that work once, this time I want to put new heads and hopefully no more probs. Question is are O-Ring heads a way to go? I found some O-Ring heads from Liberator Performance for 700.00 for the set plus 1,500 core. I just want to do the right thing. I got the truck used from and older couple that had it new and I had all the work before i had plates on it lol. 2006 King Ranch FX4 cherry. Any info or advice will help Thanks in advance!
King Rancher_27 is offline
post #2 of 20 Old 04-11-2012, 02:24 AM
I dont know anything about O-ringed heads, I was just told not to get them. I just went with a OEM replacment from Odessa heads. They seem to have a good rep on the net. The price is more then $700 for a set though and they come ready to bolt on. I just got my heads from them in the mail 2 days ago.
Did you have your heads checked for cracks when they were off or decked? Even though checking for cracks is only as good as the guy doing the checking..
05 CC SB 6.0 FX4
SCT w/ SPD
Gryphon Tuned
ARPs
New UCF Heads ported & Oringed
Blue fuel spring
sinister coolant filter
Egr Delete
5" DiamondEye TBE
BFG ATs 35s
ELC Cat-1
Scangauge
EGT/ fuel/ oil psi gauges
Bilsteins Shocks
08+ Aluminum Axle Cover
08+ Trans Pan W/Filter
MTW stage 2 DD solenoid
24+ years Ford Employee
SharkDiver is offline
post #3 of 20 Old 04-11-2012, 09:25 AM Thread Starter
Yeah I had my heads magnafluxed and psi tested and checked all the way around. I used the same shop that i used for years on all my other motor rebuilds and nerver had a problem with their work. Thanks for the reply!
post #4 of 20 Old 04-11-2012, 09:41 AM
F250SixOH's Avatar
What head gaskets did you use?
F250SixOH is offline
post #5 of 20 Old 04-11-2012, 09:52 AM Thread Starter
We used the black onyx gaskets that came with the sinister kit. Then I read a bunch of bad stuff about them. SMH!!!
post #6 of 20 Old 04-11-2012, 09:56 AM
i bet its the gaskets and not the heads, just use the ford oem gaskets
lubbock guy is offline
post #7 of 20 Old 04-11-2012, 10:02 AM Thread Starter
Deff going back with oem gaskets
post #8 of 20 Old 04-11-2012, 10:03 AM
Quoted: 370 Post(s)
Feedback Score: 5 reviews
here is a thread for yall...
Let's Play a Game
2005 F250 King Ranch Work Truck.
Studded and Deleted
175/30% Injectors from WARREN DIESEL!!
Barder Stage 2 Turbo
Warren Comp Tranny w/ PI TC
Six0~Stroker is offline
post #9 of 20 Old 04-11-2012, 10:05 AM
ars5147's Avatar
Quoted: 124 Post(s)
This is like the 4th blown black onyx HGs thread this week.
Go back to OEM and good luck.
2008 F250 CCSB 6.4
1997 F350 CCLB 7.3
2011 F150 SVT Raptor
ars5147 is offline
post #10 of 20 Old 04-11-2012, 10:14 AM Thread Starter
I would still like know what others think about o-ring heads? might buy some soon
