EBP tube !
Hey guys, first post, but been lurking a long time. My 2007 f 350 has 100,000 miles. i have been reading, thought i could easily remove the EBP tube and sensor to clean it if it needs it. I bought this truck last year with 72,000 miles. i do all of my own oil changes, fuel filter changes, coolant flushes, etc, i am very mechanically inclined.
i removed the EBP tube and sensor in about 5 mintues, to my surprise it was clean, i then spent over an hour trying to thread the tube end into the nipple on the exhaust manifold the threads looke good, i removed the ebp tube without problem, just cant thread it back on the threaded nipple on the exhaust manifold. so the next day, i tried to drive the truck to the dealer , truck blew clouds of black smoke, max speed 30mph, i got within a 1/4mile of ford dealership and truck died!, had to be towed to dealership! dealer tech could not get it theaded back on, and they ordered a new ebp tube. so i am truckless until the new tube comes in, hopefully today. Hindsight says i should have removed just the sensor at the top of the tube , cleaned sensor, use wire cable to clean tube, re install ensor and carry on. dealer price on new tube( not sure if it includes new sensor) is $180 dollars !![]() so take this as a word of warning, the threaded end of the tube may not re thread after 100,000miles. crazy as this next statement may sound, i have the complete bullet proof diesel oil cooler and egr cooler at my house. a friend of mine is a ford master mechanic who has agreed to help me on the install of this kit this weekend. currently my EOT and ECT deltas are 10-12 degrees, truck has original oil cooler, so installing this bullet proof kit is a preventive measure. |
Man that sucks! I pulled the EBP tube off mine and cleaned it no problem. Truck had 110k miles on it. Better luck installing the BPD stuff!
Your dealer is ripping you off...I did the same thing 2-3 weeks ago, turned out a previous owner did it and stripped the threads on the exhaust manifold adapter and tube end. Took 1 day for the dealer to order and cost me $65 including tax for both the tube and exhaust manifold adapter....And btw this local dealer charges nearly double for most parts compared to Tousley Ford.
The tube is a little different from my truck to yours, but it's probably about the same length and amount of bends. |
by cleaning this tube out it does what for our truck? This sensors has an input into what?
Exhaust back pressure sensor. It is used to determine what position the turbo vanes are in as well as an input to the PCM to improve injection timing. In my experience, the EBP sensors don't get as gunked up on the 6.0 as the 7.3's.
got the truck back yesterday, runs fine now, the dealer replaced the ebp tube, charged me 122 for the tube and another 60 for labor, plus tax. so i got outta there for just under 200 dollars. I think what Evil Eye said must be correct, i did not see any gunk in my ebp tube, and it was the original tube on the truck, truck had just turned 100,000miles when i checked the tube.
it is hard not to let something this simple dampen my spirtis, but i am still going to install the BPD oil cooler and egr cooler this weekend, hope all goes well.
PS. The BPD oil cooler and EGR cooler install job is no joke, but most of the parts are not delicate like the EBP tube. |
i can say the BPD oil cooler and egr cooler and oil cooler lines, all the parts in this kit are TOP QUALITY ! , i also purchased the IPR screen, oil pressure switch, bullet proof diesel truck step. going to start on the truck friday after work, hope to finish sometime saturday.
If there are ANY other powerstroke owners,or mechanics that want to come over to my house and watch, turn a wrench, etc while i am doing this BPD oil cooler and egr cooler, send me a PM message. |
