Injectors getting replaced, what else??? - Ford Powerstroke Diesel Forum
post #1 of 27 Old 04-09-2012, 06:07 PM Thread Starter
Strokeittothemax's Avatar
Well last friday my Injectors crapped out and egr valve, so while those r getting replaced, anything else I should have done???
~Ryan~
Present: 2002 F350 XLT CCLB Dually 7.3L, TS-6pos, 4" Exhaust
2013 Ford Focus ST Black
Past: 2012 CCSB 3500 Cummins (Dads now)
2007 Crew Cab Short Box F250 Lariat 6.0L
2004 CCSB LB7 Duramax EFI Live
Strokeittothemax is offline
post #2 of 27 Old 04-09-2012, 09:23 PM
Ford 6.0 Update Turbo Oil Drain Tube
SKU: 6C3Z9T515A
Ford 6.0 STC HPOP Fitting Update Kit
SKU: 4C3Z9B246F
Ford 6.0 Updated Stand Pipes
SKU: 6E7Z-9A332-A
Ford 6.0 Updated Injector Rail Plugs AKA "Dummy Plugs"
SKU: W302908
Ford Fuel Pressure Regulator 2003-2007 F250,F350,F450,F550 6.0 International VT365
SKU: 3C3Z-9T517-AG
Ford Turbo Feed Line 2004-2007 F250,F350,F450,F550 6.0 International VT365
SKU: 3C3Z-9T516-A
2 stroker
06 F350 4x4 PSD Lariat FX4 CC LB
Edge Insight CTS Expandable Pyro
AutoMeter Fuel Pressure Gauge
Updated Fuel Reg. Kit 3C3Z-9T517-AG
Amsoil By-Pass(Amsoil 5w40)
Delo ELC Coolant
Coolant Filtration System
pulling a 14,000 lb Alpenlite 5er
97 F350 4x4 PSD CC LB
PacBrake&ATS converter lockup
3" dp 4" exhaust
TruCool 28,000 lb cooler
Tymar Intake
A piller EGT,Boost,Trans
2 stroker is offline
post #3 of 27 Old 04-10-2012, 04:22 AM Thread Starter
What do you think killed my injectors in the first place??
~Ryan~
post #4 of 27 Old 04-10-2012, 05:30 AM
Razorsedge's Avatar
Have you checked your FICM?
2005 F250 4x4 King Ranch 6.0
Two tone removed, Quad Captains, High idle mod
Edge Insight CS w/ EGT, fuel PSI, and turbo timer
4" turbo back straight pipe, Dieselsite coolant filter
BPD FICM, '03 turbo, IPR gen2 delete, Zerex ELC
Goodyear Duratracs, Tuned by Matt@Gearhead
Razorsedge is offline
post #5 of 27 Old 04-10-2012, 05:37 AM
Turbos = Witchcraft
TooMuch03's Avatar
Feedback Score: 3 reviews
I would guess FICM or low fuel pressure.
2003 F250 6.0
Originally Posted by Tuscany View Post
Compounds FTW!!!
TooMuch03 is offline
post #6 of 27 Old 04-10-2012, 07:10 AM Thread Starter
Ficm was replaced 2 months ago but he checked that and it was good... must have been low fuel pressure.
~Ryan~
post #7 of 27 Old 04-10-2012, 09:07 AM
Fuel pressure under 45lbs at WOT kills injectors, mine at 17k had a fuel pressure of 44lbs at WOT and 50lbs at idle now after the blue reg spring WOT 58lbs and idle 62-64lbs.
2 stroker
Delo ELC Coolant
3" dp 4" exhaust
Tymar Intake
post #8 of 27 Old 04-10-2012, 10:54 AM Thread Starter
Will bigger injectors blow the original head bolts? thanks!
~Ryan~
post #9 of 27 Old 04-10-2012, 11:27 AM
Not with a good tune and tuner. they know what will cause headgaskets to blow and will stay on the right side of that line.
08 F350 CCSB Lariat - massaged exhaust, MiniMaxx, AFE Stage 2, Flo-Pro CAC pipe, CCV modded 2" leveling kit. soon to come - EGR delete, sinister intake elbow
Traded in 06 F350 CCLB - 5" diamond eye exhaust, sct (removed before selling), coolant filter, high idle
Zeek is offline
post #10 of 27 Old 04-10-2012, 11:54 AM
Turbos = Witchcraft
TooMuch03's Avatar
How big is bigger? Zeek is right, with the right tuning you can pull enough fuel out and not be aggressive with the timing to make you headbolts last... as long as any headbolts last lol
2003 F250 6.0
Compounds FTW!!!
