Low power under 2000 rpm - Ford Powerstroke Diesel Forum
post #1 of 5 Old 04-06-2012, 09:10 PM Thread Starter
So I've always known my truck was weak off the line and was unable to power brake, but today I was parked with front tires against a curb and I tried to drive over it with no luck. Kind of embarrassing. My rpms would only rise to 1500 then and that was it. Had to back out of my parking spot like the regular folks! Truck drives fine with no other complaints other than not much power until 2000 rpm(thats when it comes to life). It makes me doubt the trucks ability to pull my boat out of the lake. Is this something that can be solved with a sct? Any suggestions would be appreciated.
2003 F-250 6.0l 4x4
4" lift
35" General Grabbers
AFE intake
5" FloPro TB exhaust
dmcclurg28 is offline
post #2 of 5 Old 04-06-2012, 09:16 PM
2003kingranch's Avatar
Cleaning your turbo, and scanning for codes would be a great start. Your turbo is likely sticking
2012 King Ranch
22k deleted at 1k
5" FLO-PRO
S&B Intake
Sinister Egr Delete
MiniMax/ SPE Tunes
466/953 on 37's
6" 4 link
37's on 22's
Bags and compressor
RBP mudflaps
transfer tank tool box.
9" 2" poly boss v blade
Should have kept my 6.0.....
2003kingranch is offline
post #3 of 5 Old 04-06-2012, 09:19 PM Thread Starter
Turbo was replaced one year ago and no codes appear when I scan it.
post #4 of 5 Old 04-06-2012, 10:05 PM
Clogged EGR?
lethald is offline
post #5 of 5 Old 04-07-2012, 06:42 AM
Quoted: 14 Post(s)
Unfortunately many code readers do not read all of Ford's codes.
A one year old turbo can still have stuck vanes/unison ring. Is the VGT solenoid connector fully seated? Have you done any recent work that might have left a sensor unplugged?
Mark
06 F250CC SB FX4 Lariat;ARP studs;OEM gaskets; Banks exhaust;DynaTrac Ball joints;Coolant filter; High-Idle;RACCCV6000;JimmiJammers;Ravelco;SynchroMax trans case;Fumoto valves;Harpooned;CPOhighwayProducts toolbox;tracrac;Fox Weatherboots;Wet Okole Seat Covers;BriteBox;Re-flashed;Quadzilla Recon XZT Fuel Press;Blue FPR spring;DashDAQ;PHP FICM;RiffRaff boots;DCPower270AXP;PowerInverter;Rancho7000's; BPD EGR cooler;One-piece HPOP fitting;BilletWaterPump;SCT w/ Matts SRL;ELC Ultra
bismic is offline
