Gauges plz help - Ford Powerstroke Diesel Forum
Old 04-06-2012, 03:38 PM
Gauges plz help
I need gauges for my truck and wanted to look at some brands what brands do y'all run in yours? An let me know what y'all think.
Old 04-06-2012, 03:49 PM
I just ordered a dashboss for mine.
Old 04-06-2012, 04:24 PM
information regurgitator
I have an old edge insight and a three gauge pod that holds the boost, oil pressure and fuel pressure gauges. The Insight is set to watch EOT, ECT, EGT (added the probe) and TFT.
Old 04-06-2012, 04:50 PM
I have a similar setup to this. I highly recommend the Edge Insight, either CS or CTS.
Old 04-06-2012, 04:53 PM
I don't have a 6.0L but I have Glowshift gauges and have no complaints.
Pod and boost, EGT, trans temp for 217 shipped.
Old 04-06-2012, 05:23 PM
Feedback Score: 3 reviews
Depends on how deep your pockets are and what you prefer.
Most go with the Edge Insight CS/CTS with expandable cable for EGT and fuel psi.
Then their is the ScangaugeII, then add 2 analog gauges for EGT and fuel psi.
If your using a Android based phone, check out the Torque App, then add analog gauges for EGT and Fuel psi.
If your rocking a iOS device like iTouch/iPhone/iPad, you can check out DashBoss and add the external ports to read EGT and Fuel psi.
And if you like the old school analog gauges, be prepared to spend some money on enough gauges to match the capabilities of the already mentioned digital monitors.
I run 7 analog gauges and the DashBoss with external ports for EGT/Fuel psi.
