hit 100,000 miles, want to change front and rear end fluid - Ford Powerstroke Diesel Forum
post #1 of 7 Old 04-04-2012, 06:20 PM Thread Starter
hazard's Avatar
hey guys, well my 06 turned 100,000 miles on sunday, im due for a service but am waiting for my oil to come in at work so im holding off on my oil change and stuff until then. I got to thinking it may not be a bad time to change the front and rear end fluid, i doubt its ever been done and now would be that time, so if anyone would be so kind as to what type of fluid, how much fluid and how much limited slip additive or what type/kind (part #) i need, i would greatly appreciate it, if there is a better option than the oem motorcraft fluid let me know im all ears. thanks alot guys. Any opinions on anything else i should do for my 100 k check up im all ears, i really havent had any problems with the truck whatsoever, only thing its had done is 1 ficm and head gaskets. that is it. I love my 6.0 its been darn good to me and i definetely want to keep it that way.
Thanks,
Adam
2006 F-250 6.0L CCSB Lariat 4x4, ARP studs, SCT tunes by innovative diesel, Silverline 4" turbo back exhaust no cat no muffler! Upfitter switches w/high idle mod, Edge Insight monitor w/EGT probe, autometer fuel psi gauge, Zoodad mod with billet plate. Ford Updated fuel psi spring and banjos, RCD egr delete, Ford updated oil cooler and stc fitting, dieselsite cac boots and coolant filter.
1984 Mercedes Benz 300D Turbo Diesel, cold air intake.
"Run Hard, Dream Big"
hazard is offline
post #2 of 7 Old 04-05-2012, 09:14 AM Thread Starter
hazard's Avatar
Bump to top
Thanks,
Adam
hazard is offline
post #3 of 7 Old 04-05-2012, 09:24 AM
Quoted: 364 Post(s)
Feedback Score: 5 reviews
2005 F250 King Ranch Work Truck.
Studded and Deleted
175/30% Injectors from WARREN DIESEL!!
Barder Stage 2 Turbo
Warren Comp Tranny w/ PI TC
Six0~Stroker is offline
post #4 of 7 Old 04-05-2012, 11:03 AM
HMM
HMM's Avatar
Quoted: 2 Post(s)
Double check but I believe this is the correct fluids:
Front Diff: 80w90
Rear Diff: 75w140 + 8 ounces of friction modifier - unless the synthetic you get has some in it already (should say if it does)
Some say they use 75w140 for both or 75w90 for the front. I have 4 quarts of red line 75W90 in the garage from my old truck so odds are that's going to be what I use for the front.
Just splurge and go synthetic. Also change the transfer case oil too, 1 bolt to drain and 1 to fill. And if splurging on synthetic still leaves you with money to spend, get an 08 rear diff cover (around $50ish plus you sourcing new (longer) bolts).
2006 Dark Shadow Gray Harley #898
HMM is offline
post #5 of 7 Old 04-05-2012, 11:17 AM
HMM
HMM's Avatar
Quoted: 2 Post(s)
Also found this site while I was searching to confirm my numbers above, mash me. It has some good pictures to go by.
HMM is offline
post #6 of 7 Old 04-05-2012, 11:19 AM
Baddestt's Avatar
Quoted: 8 Post(s)
I run amsoil 80w90 synthetic in the front, Mobil 1 synthetic ATF in the transfer case, and Amsoil Severe Gear 75w110 in the rear. You will need 3 quarts for the front, 4 for the rear, and 2 for the transfer case. If you don't tow heavy loads much, you can get away with the 75w110 in the rear and pick up about 1mpg mileage improvement. And when I had the stock ford posi in the rear, I never used friction modifier with the amsoil, and it still worked as intended from the factory.
'07 F-250 PSD 4x4
5" exhaust, zoodad, blue spring, Airaid intake, 6.4 starter, 2.5 f/coils, adj Trac bar, 2" r/add-a-leafs, egr delete, snow plow fan clutch, csf 6028 intercoolerr, DC 185 alt, Bilstein 5100, Barder '03 turbo rebuild w/RR billet wheel, SCT SF3 tuner, F-Detroit Truetrac, R-Detroit Locker, 4:10 gears, hawk LTS, LT315/70r17 Duratracs, Amsoil Gear lube, Delo 400 LE 5w30 diesel, Delo ELC, archoil, bpd ficm, BPD oil cooler, dynatrac pro steer ball joints, arp studs, oem gaskets, HD water pump, stc, plugs, stand pipes, 6.4 banjo bolts,
Baddestt is offline
post #7 of 7 Old 04-05-2012, 11:21 AM
still runs's Avatar
when fill back up do you fill to the bottom of the fill hole or is there a certan amount qts that are supose to go back in ?? i know my gear oil has never been changed
never mind thanks
arp studs and all new gasgets
blue spring.... its really blue
full egr delete
Bts tranny
coolant bypass and fillters
rotella red elc
cummings 5.9l banjo bolts
4 inch turbo back
Custom tunes by spe
2.7 leveling kit
next on the list
new injector$ $$$$$
regulated fuel return
ficm & ecm to php along with my evo to be flashed
and half in my 401k lol
still have my 401k all of it
SYLSOS
still runs is offline
