Intermittent white smoke........hmmm - Ford Powerstroke Diesel Forum
post #1 of 22 Old 04-04-2012, 03:56 AM Thread Starter
badyota82's Avatar
I posted this in the problems area, but havent gotten any responses so thought i would try here.
I would like to just get some opinions on this.
Let me start off by saying, truck starts, runs, drives, sounds great and completely normal. Its studded and deleted. No coolant loss or abnormal temps.
Last week one day on break, i drove to the convenience store up the street, left it running, drove back to work and as i was backing in the parking space i noticed it puffing a little white smoke, like just a haze, not a fog cloud. Then saturday I drove it, shut it off in the drive way and was not smoking when I shut it off, then about 30 minutes later fired it up to move it to the barn to load a few things, and it was puffing white smoke again. Not alot, just a haze. Smoke smells like diesel, not coolant. Then Sunday, pulled up to house, no smoking, shut it down, then bout 5 min later fired it up to move it and there was the haze again.
Seems to do it after its shut down for a short bit and fired back up. Doesn't do it going down the road, and now that its caught my attention, i've been watching like a hawk, and only noticed it these 3 times.
Injector O-rings???
Thanks
2006 F250 Lariat CC FX4
Current Mods:
4" MBRP Exhaust
58v FICM w/ performance flash
Blue FPR Spring
SCT w/ tunes from Matt (SRL, 8k Tow, Unlim. Tow)
Edge Insight CTS
1200rpm High Idle
Coolant Filtration System
6.4 Banjo Bolts
ARP Head Studs
EGR Delete
Sold: 1997 F250 PSD 4x2 5 speed
badyota82 is offline
post #2 of 22 Old 04-04-2012, 07:05 AM
mxc
mxc's Avatar
i had a similar problem on my truck except it was smoking white on cold starts and then it would clear up. put in some rev-x and about a week later i got no more smoke and it's running perfect. must have been injectors sticking.
2005 F250 FX4 6.0 Auto SCSB Sport Pkg.
6" lift on 37" Toyo's and 18x10 Classic Locks
EGR delete, Cat ELC coolant, Sinister coolant filter
03 Turbo swap, 5" straight pipe, Airaid intake w/ zoodad
N-fab wheel to wheel steps so my girl can get in haha.
mxc is offline
post #3 of 22 Old 04-04-2012, 07:34 AM Thread Starter
badyota82's Avatar
Probly wouldnt hurt for me to run some rev-x thru it. 129k on stock injectors. Where is the best place to get it?
Current Mods:
4" MBRP Exhaust
Blue FPR Spring
Edge Insight CTS
1200rpm High Idle
6.4 Banjo Bolts
ARP Head Studs
EGR Delete
post #4 of 22 Old 04-04-2012, 10:05 AM
You can get it at Rev-X's website. or on Ebay sometimes it's cheaper.
If you want to know more than you ever really thought you could about injectors, read the link on them in my sig below. It explains what, why, how, and what to do to fix it.
No Power? No Boost? Check/Clean your EGR VALVE!
2006 F350 SWR Lariat
-EGR Delete
-Evans NPG+ Waterless Coolant
-ZERO Pressure Coolant system
-Dieselsite Coolant Filter
-Mini Maxx Monitor/Tuner
-Blue Spring
Dicion is offline
post #5 of 22 Old 04-04-2012, 11:00 AM Thread Starter
badyota82's Avatar
Great thanks for the info!
Current Mods:
4" MBRP Exhaust
Blue FPR Spring
Edge Insight CTS
1200rpm High Idle
6.4 Banjo Bolts
ARP Head Studs
EGR Delete
post #6 of 22 Old 04-04-2012, 12:36 PM
ebusa's Avatar
Hows your FICM?
-Evan
Semper Fi
2005 F350 Crew Cab LB FX4 Lariat
Loaded-Leather, Sunroof, 06 Chrome Package
5'' Tuff Country Lift
Toyo MT's 35's with Race Line Renegade 20's
ARP Studs, EGR Cooler Delete, Coolant Filter
MBRP 4'' Exhaust Turbo back, No Cat
SCT X3 Tuned by TSD & IDP
Stock Airbox, NON-MAF Truck
GT3788VA POWERMAX Turbo
DiProcol Optix EGT & Boost Guages , Scangauge II
ebusa is offline
post #7 of 22 Old 04-04-2012, 12:57 PM Thread Starter
badyota82's Avatar
It's a 58v swamps with the performance flash. Less than 8 months old. Voltage is a steady 48v as indicated on the CTS.
Current Mods:
4" MBRP Exhaust
Blue FPR Spring
Edge Insight CTS
1200rpm High Idle
6.4 Banjo Bolts
ARP Head Studs
EGR Delete
post #8 of 22 Old 04-05-2012, 12:47 PM
mxc
mxc's Avatar
got my rev-x from little power shop on ebay. they shipped it expedited and it came in 2 days.
mxc is offline
post #9 of 22 Old 05-10-2012, 01:15 PM Thread Starter
badyota82's Avatar
Ok so I figured I'd update. Took truck to stealership since I have ford ESP. They diagnosed as bad turbo seals. Rebuilt turbo, and a week and 300 miles later, still smoking. Took it back, and they checked intercooler to see if it had a crap load of oil in it. Found nothing. Now they are saying that it has low compression on all 8 cylinders. WTH?! Now just food for thought, it has only been about 3000 miles since they changed head gaskets. This truck never smoked one bit effort the head gasket job, now all of a sudden it is.
Please help with any advice or ideas.
Thanks!
Current Mods:
4" MBRP Exhaust
Blue FPR Spring
Edge Insight CTS
1200rpm High Idle
6.4 Banjo Bolts
ARP Head Studs
EGR Delete
post #10 of 22 Old 05-16-2012, 07:20 AM Thread Starter
badyota82's Avatar
Any ideas?
Current Mods:
4" MBRP Exhaust
Blue FPR Spring
Edge Insight CTS
1200rpm High Idle
6.4 Banjo Bolts
ARP Head Studs
EGR Delete
