Status
Not open for further replies.
33's vs. 35's
13K views 16 replies 11 participants last post by  6.0DSLPWR
#1 ·
hey guys,
I'm pretty new to the forum but I have been doing a lot of research on tires. I am lost right now because being 19 and trying to buy 1500 dollars worth of tires is kind of a big purchase for me. lol. damn college. Anyway, I have 33's right now (325/60/18) and I can't decide what to get for my next set. I really like the tires I have now which are hankook dynapro m/t but I have a 4.5" lift and I was thinking about moving up to 35's. I really would like to know the amount of power loss between the two sizes and how the road manners are when you move up to 35's. I'm aware that I will lose fuel mileage but you play you pay i guess lol. Any help or advice would be much appreciated. Oh and to clarify I have 3.73 gears in the rear end
Thanks
#2 ·
I would like to know all of the above as well. I have 33's and when I get these down I'm gonna go to 35's but I don't want to loose to much fuel mileage. But I had 35's on my other truck and they didn't really wander the road bad or anything like that. I haven't really had this truck in the rain with big puddles and stuff yet but my other one you know big wide tires hit puddles and it can scare you a bit.
#3 ·
well like in the other thread thats going on right now imo your going to be ok its a little sluggish off the line thats about it once there rolling there rolling. little harder on tierods and stearing linkage at a stop or slow creaping when turning the wheel but you wil be ok nothing has changed with my truck as far mpgs
#4 ·
I can't attest to the power loss, but I run 37's on my truck and know of a few other that run that size or bigger with no problems. Drives fine. I have taken my truck on 2400 mile road trips and I drive 80mi a day total, to and from work on 37's. So driveability should be fine. BTW, mine is a 7.3, but I also have 3.73 gears so I don't think it will be a huge problem.
-Aaron
#5 ·
A little of topic but do you guys think 35's will fit under a 2006 f350 with stock suspension
#7 ·
Depends on the rim but there is about a 99.5% chance that it will need the fenders trimmed. (Don't forget 89% of statistics are made up on the spot) :p
Seriously though....Probably not without trimming. I had a buddy with a 2002 (A little different, I know) that ran 35's with a leveling kit and he still had to trim a hair on the fenders.
-Aaron
#12 · (Edited)
Statistically speaking, 60% of the time, it works every time. :hehe:
Anyways, I run 305 70s on a 16x10 rim on my 04 and they only rub at full lock on the inner edge of the mud flap. The truck is leveled too. But with a lift you should be fine with 35s. When you calculate mileage, make sure you compensate for the taller tire but even doing that you will lose some mpgs.
#9 ·
its still fun and im stock and rub at full turn only you will be ok the 05 and up have a littlr more clearance than the 04 and earlier get a 2.5 leveling kit you will be golden
#13 ·
35s will decrease MPGs due to higher weight and higher truck height..air resistance. Honestly I know we love the better look but I'd waited until mid summer to buy (when fuel is at it's highest) that way you'll get a better tire deal and the cost will go down throughout the year to drive the truck.
35s if balanced correctly do not wander.
Factory is 245/75/17 (31.4") thus equal 3.73
From Factory to true 33s makes a 3.56 rear end ratio
true 33s to true 35s makes a 3.52 rear end ratio
Thus you will lose very little power, and it will be off the line where you'll feel it
Status
You have insufficient privileges to reply here.
