P0401 Need Help!! - Ford Powerstroke Diesel Forum
Old 03-30-2012, 07:55 AM
P0401 Need Help!!
Hey guys,
weird thing happening, couple weeks back I replaced my thermostat on my truck and ever since I have been getting a check engine light for EGR insufficient flow (P0401). I do have a EGR delete and I have custom tunes from Vivian at quick tricks to turn off the EGR stuff, anyone have this happen or have any ideas of how to fix it?
Thanks!
Old 03-30-2012, 08:03 AM
Feedback Score: 3 reviews
Give Vivian a call, she can either fix the current tune, or send you a new one.
She might of forgot to turn off the EGR in the tune, poop happens!! We are only human.
Old 03-30-2012, 08:05 AM
Thats the problem tho, I gave her a call and she said it was turned off.... I don't know where to go from there...
Old 04-04-2012, 03:15 AM
Has anyone had something like this happen?
Old 04-04-2012, 04:21 AM
What are you using to pull up codes???
You may have other codes, but whatever scan tool your using may only be able to show the p0401 and not the others.
Old 04-13-2012, 07:39 AM
I am using a edge CS insight
Old 04-13-2012, 05:01 PM
Check the wires to your MAF sensor, they clip to the oil dipstick tube. they become brittle and break, maybe you tweaked a wire while doing the Thermo. Give them a tug, they should be able to take it, other wise you'll see the insulation stretch if the wire is broken internally.
Old 04-15-2012, 05:14 PM
How do you fix the wire if it broke? Crimp them back together?
Old 04-15-2012, 05:23 PM
You need to buy the pigtail from ford, its a pretty common problem, I was chasing that for a little while
Old 04-15-2012, 05:49 PM
I just looked and they seemed to be in tact, gonna look harder tomorrow when I have more light, but I know my air filter doesn't line up perfectly, think that could trip that too?
