Flushing Question
So I'm planning on doing my oil cooler and egr delete on Easter weekend (April 7th). I know your supposed to flush the coolant system before doing this project and I will be doing so on the Monday before that weekend. If i flush it on Monday, will I need to flush it again right before the oil cooler swap? And if yes, than can i run a lesser concentration of coolant to water in a effort to save money?
I thought that I would just do the flush Monday, drive it for the week, then drain just enough coolant into a clean bucket to do my planned work and pour the drained fluid back in. Sorry for the long azz post ![]() Sent from my DROID RAZR using AutoGuide.Com Free App |
You wont need to flush it again. How long have you had the coolant filter on?
2 stroker |
Not just water, distilled water. Dont keep tap, well or any other faucet Watter in your cooling system other than for the flush.
The only reason this came up is my dad thought we may have to drain alot for the delete and oil cooler but either way it should be reusable. Im thinking of filtering it as I pour it back in to the degas as an extra precaution. |
You should have run it for about 7000 miles before you replaced your oil cooler. You might had clogged your new oil cooler. You might try a reverse flush like this weekend.
I need to do something asap though. Im seeing deltas sometimes of 35 almost 40 on the highway at 65-70mph In town it gets up to 20 sometimes. Not sure how she hasnt blown the egr yet. Should I do just the egr and flush this upcoming weekend and save the oil cooler for a little later?
2 stroker |
I have been pretty easy on it since i bought it a few months back, knowing it didnt have studs or an egr delete. I will definitely turn the filter off, good idea I guess ill just flush it and keep running a filter and see what happens hopefully i wont need to do it again.
So what's going to happen if I can only flush my coolant on Friday, the day I was planning on starting on the egr delete and oil cooler?
No one has any ec1 concentrate and has to order it. Sent from my DROID RAZR using AutoGuide.Com Free App |
