I need some help, when using the distilled it only took 4 gallons... do I only need to put 2.5 gallons of coolant?
Sent from my DROID RAZR using AutoGuide.Com Free App |
No... I think its 3.5 gallons (check the procedure) of coolant...
When you flush there is water left in the block. So when you put x amount of coolant in you bring the mixture to 50/50.. At the end you might only need to add a gallon or two of water. Sent from my DROIDX using AutoGuide.Com Free App |
![]() Its all flushed and it took forever. Just drove 100miles to hang with my girlfriend and but some filter miles on the new coolant. Non of the temps have changed any, if anything, it stays cooler Sent from my DROID RAZR using AutoGuide.Com Free App |
Good stuff!!!
moments Sent from my DROID RAZR using AutoGuide.Com Free App |
No problem bud
That's what we're here for!!! Sent from my DROIDX using AutoGuide.Com Free App |
Huh I think I put mine back in when I put the truck together...
I would be worried of the heat burning the firewall insulation if the heat shield wasn't installed. Sent from my DROIDX using AutoGuide.Com Free App |
I don't remember... did you change your oil cooler???
