You don't want to leave water in there because it will start to RUST then down the road the coolant will be red on it's own. Go to napa and get this NAPA AUTO PARTS There are many modern Heavy Duty Extended Life Coolants specifically designed for diesels. Delo ELC, Rotella ELC, International's Fleetrite ELC, CAT ELC, Mobil 1 ELC, and a host of others. They will address diesel cavitatation, provide superior metal corrosion protection, provide better heat transfer, require no testing and maintenance, be free of harmful abrasive silicates, borates, and phosphates, and have an operating life up to 1 million miles (Delo ELC). In fact International, who made your engine, recommends and factory-fills with these Heavy Duty Extended Life Coolants (Fleetrite ELC/Shell Rotella ELC). And in fact almost all heavy duty diesel manufacturers use Heavy Duty ELC's meeting the most strict requirements in the industry...Caterpillar's EC-1. 2 stroker |
You might clog your new oil cooler because if you flush and RIGHT AWAY change the oil cooler you still might have some crap left in the system that will eventually go through and get stuck in the NEW oil cooler... I suggest flushing and driving a couple days to clean the system completely before starting the oil cooler job |
Should have been more proactive with the coolant, thought it was common enough people stocked it, I was wrong, no one round here seems to even know what it is ![]() Sent from my DROID RAZR using AutoGuide.Com Free App |
How many gallons of distilled water are really needed? Do I have to do each flush with distilled water or can I just do one or two rinses before I but in the ELC?
A lot. The resin is because you have to make sure all of the restore is out of the system. You need to test with PH strips to make sure it's right and then you add the 3.5 gallons of an ex rated elc coolant. This is all done this way so you know you have the correct mixture.
I think i bought about 30 gallons ![]() It's ok to flush a bunch of times with tap water and then just do two- three flushes with tap water to clean all that tap water out of there... |
Thats what my plan is, I bought enough water to flush it twice. Dont you mean distilled :
I used 48 gallons 2 flushes to ditch the Gold 5 flushes for the Restore 6 flushes for the Restore+ till i had a 7.0
![]() 2 stroker |
To dilute the tap water left in your cooling system, you have to flush it 7-8 times with distilled.
The math: After the first flush using distilled, you will have about 50% tap water in the cooling system. (assumes 50% of total capacity drained at each flush, YMMV) The second, you will have 25% The third, 12.5% The fourth, 6.25% The Fifth, 3.12% The sixth, 1.6% The seventh, 0.8% The eighth, 0.4%..and on it goes. I used about 40-45 gallons of distilled water to do all of the flushes I had to do. Yes, that is an awful lot of water, but I looked at it like this: If I drop 50 bucks for the distilled water, I didn't have to worry what could be lurking in the tap water or if I got whatever was in the tap water diluted enough to not cause a problem later. At that point, 50 bucks was cheap insurance. |
