Welp my new rig needs a hpop. Where is a good place to get one I was looking here.Factory Replacement (HPOP) High Pressure Oil Pressure 6.0L Powerstroke 2003-2004 Only. Is there any special tools I need to change this ? Do I need to change my Ipr when I do this as well ? thanks guys
What exactly are the signs of a bad hpop and what happened to your white truck? The grey truck is very nice too! Is that just a leveling kit?
Thanks and yep just a leveling kit sits as high as my buddys 250 with a 4" lift and I rolled my white truck unfortunately. For me in both cases just a extreme loss in power. No top end power at all.
You wouldent happen to know exactly what leveling kit is on it do you? And if it has trac bar drop bracket or not?
No track bar and I think just a add a leaf setup up
Still need help on finding a hpop
I bought mine from tousley it was 682 total but they return 150 when you send in your core, you also get 12000 mile warranty with the new pump. my best suggestion
3C3Z 9A543 AARM / 5010106R93---------------------------------HPOP(High Pressure Oil Pump) 2003/Early 2004))*
4C3Z 9A543 AARM (Late Build 2004)* 5C4Z 9A543 C / 5010119R92-------------------------------------HPOP(High Pressure Oil Pump) 2005/2006/2007))* |
Thanks man ! What gaskets do I need to replace while I'm in there
