turbo codes - Ford Powerstroke Diesel Forum
Old 03-28-2012, 06:57 PM
turbo codes
I have an 06 F350 king ranch 6.0 with a banks power pack system installed. this includes a new inter-cooler and the updated controller. every once in a while I get a check engine light and when I check the code it tells me i have a slow turbo response or lack of boost. The truck runs fine and doesn't seam to have any lack of response I pull a 15,000 lb fifth wheel and it usually happens when I am towing. What could be going on and is this a major problem to really address. I only have 35,000 miles on the truck
Old 03-28-2012, 08:30 PM
Well it looks like you need to clean your turbo
DTS Articles - Turbocharger Reconditioning
This will help you in how to clean the turbo. Do you run any cetane boost in the fuel and once a week you need to drive it like you stole it to keep the egr valve and turbo clean and working and max boost is 28lbs mine solo runs 25lbs but with my 5er i can hit 28lbs easy have to back out of it.
2 stroker
