Can a FICM be tested off the truck?
I have a couple of spare FICM's laying around from parted out trucks and would like to know if there is a way to test them to make sure they are good without having them installed ona truck. Thanks
Anyone? Thanks
Technically you can, but you could only test the power supply portion of the circuits and you would need injectors that could be wired up to the FICM.
You could build a test bench.... PCM, wiring harness, injectors, FICM...
I wonder if PHP can check them out if i send one in for a rollback?
