CAT ELC coolant - Ford Powerstroke Diesel Forum
post #1 of 6 Old 03-28-2012, 03:32 AM Thread Starter
gitchasome's Avatar
CAT ELC coolant
Hey Guys, I have a buddy who just purchased a 6.0 and is wondering if he should do a coolant flush and get CAT ELC coolant, thoughts, opinions?
Thanks!!
gitchasome is offline
post #2 of 6 Old 03-28-2012, 03:53 AM
shustack's Avatar
Thats what alot of ppl on here recommend. I my self just switched to it. 5 gallon of the concentrated was around 130 bucks plus how every much distilled water u need.
04 F250 6.0 Diesel 6 spd- MBRP 5'' Full Exhaust, Dieselsite Coolant Filter, Cat EC-1, Blue Spring Upgrade,Edge Insight CTS with a Egt Probe and Fuel Pressure, Amsoil in Everything
91 Mustang Lx- Boss 347 Stroker, 9.1 Trickflow twisted wedge heads, 76mm turbo, level 6 T56 Magnum and much more
93 Mustang Gt
shustack is offline
post #3 of 6 Old 03-28-2012, 04:26 AM
jesilvas's Avatar
Quoted: 2 Post(s)
Has he monitored ECT and EOT?
He needs to be filtering it first thing, right away. He might can get away with running gold for a while.
Depending on his temps, a flush won't do much.
4R100, 2wd
330,000 + miles
jesilvas is offline
post #4 of 6 Old 03-28-2012, 05:45 AM
I shouldn't think it matters if he doesn't know his deltas. The thread starter's friend should invest in a monitoring system and a coolant filter to collect casting sand out of the block. There has been a huge article on coolant regarding the gold stuff, can't remember where it is. I would tell your buddy to grab some restore and/or vc-9 and do a proper flush.
2004 F350 PSD
8" Icon, Loud Pipe, 58v FICM, Deleted, MudGrapplers, Edge Insight, Sct tuned by Vivian.
2011 F350 PSD
AFE , Airbags, Recon, BMF , Nitto,
20046.0 is offline
post #5 of 6 Old 03-28-2012, 09:21 AM Thread Starter
gitchasome's Avatar
Yea I mean he just got the truck this week so he doesn't have anything but he is looking to do an EGR delete, I am still running ford gold **** gonna be switching probably next month over to the CAT ELC ****, he was wondering if he should go ahead and do that or just keep the ford gold stuff
2005 6.0 Powerstroke
EGR Delete
4in MBRP straight Piped exhaust
Edge Insight CS
SCT custom tunes from Vivian @ Quicktricks
post #6 of 6 Old 03-28-2012, 10:47 AM
colonel angus's Avatar
Quoted: 2 Post(s)
He should get a set of ARP Studs, Scan Gauge II, ID Tunes, EGR Delete, Coolant Filter, HPOP upgrade, STC Fitting, Blue Spring, Stand Pipes, Dummy Plugs and then once he's done tearing the engine apart then go to Rotella 5w40 and ELC.
At least that's the path i wished i'd have took.
D
colonel angus is offline
