clearance lights - Ford Powerstroke Diesel Forum
post #1 of 4 Old 03-27-2012, 08:51 PM Thread Starter
jordan07's Avatar
clearance lights
ok so my clearance lights the very end ones so far left and far right ones dont work put new bulbs in made sure the contacts and wires all look good and they do but the 3 middle light s work ? any ideas?
jordan07 is offline
post #2 of 4 Old 03-28-2012, 01:37 AM
I've installed a factory set on an earlier F-series, here is what I learned, each light is "pigtailed" on the harness, so there is a connector for each light. You may have a corroded connection, if it's corroded, you may have a water leak. I would pull down my headliner to be sure. And BTW, before you start tearing into things, did you check the bulb socket with a test light for power?
2004 F-250 XLT- FX4 - 4X4, Supercab, 8' bed, BRIGHT RED, Flint Gray Interior, 6.0 Torqshift
Sinister EGR Delete
Rotella ELC
Gutted throttle body
Coolant filter
Stator delete
Blue spring, 6.4 banjos
NChornet CCV mod
Rotella 5W-40 T-6 oil, Motorcraft filters
EDGE CTS monitor
DELTAJOHN is offline
post #3 of 4 Old 03-28-2012, 09:20 AM Thread Starter
jordan07's Avatar
yes i put a test light on it shows no power?
jordan07 is offline
post #4 of 4 Old 09-04-2012, 04:45 AM
houston1987's Avatar
Hey Jordan I know this post is from months ago but I am curious to know what was causing your clearance light issue??? I have an 07 350 srw bought about a month ago, clearance lights were working properly after purchase and just yesterday realized everyone of them was out.. I have not put a test light to one yet but plan on it very soon. Just wanted to get ideas from your experience!!!
houston1987 is offline
